Buying a used MINI - help
Old Apr 14, 2009 | 10:08 AM
newusersID's Avatar
newusersID
new member here. i need help, i am considering buying my first mini-cooper this week. but, i am unsure if i should save money and get an older car, with higher miles.
are minis reliable over all?
what major/minor issues, can i expect when buying a 2004/2005 cooper.
also, the cars ive seen have on avg 60,000 to 80,000 miles?
any advice would be appreciated... thank you
Old Apr 14, 2009 | 10:32 AM
tazio's Avatar
tazio
04 with 95k here and it has been prettty solid. No unexpected repairs to date. Just did my clutch preemptively, but it probably had at least another 10k on it.
Old Apr 14, 2009 | 10:36 AM
jsharra's Avatar
jsharra
A guy called in to Car Talk a few weeks ago with an 04 MCS with a noise he was trying to identify. He had 278,000 miles on it, and it was still on the original clutch.
Old Apr 14, 2009 | 11:17 AM
newusersID's Avatar
newusersID
thanks
what should one look for when buying a used mini?
note:
i am not mechanically inclined.
Old Apr 14, 2009 | 11:41 AM
bigsoup52's Avatar
bigsoup52
IMHO, the 2005 & 2006 models have a better tranny than earlier models. After 2006, (the end of 1st generation), the engines and body panels are different on the 2nd generation model years. In the S model, the 1st gens are super-charged and the 2nd gens are turbo-charged; again, a different design, but both gens are pretty solid from 2005 on.
Old Apr 14, 2009 | 12:38 PM
bigsoup52's Avatar
bigsoup52
newusersid,
More info for you; the www.motoringfile.com website has many articles/reviews covering all the mini models. Here is a link to a survey you may find interesting; http://www.motoringfile.com/2008/12/...-should-i-buy/ Good luck with your research, warning, this could become an obsession!
Old Apr 14, 2009 | 12:52 PM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
I have an '04MCS with no major problems, 50k miles.
If I were buying today I'd buy an '05 or'06.
Old Apr 14, 2009 | 06:42 PM
tazio's Avatar
tazio
Different ratios, but not necessarily better. The spacing is wider across the first 3 gears in the later version, and all gears have lower ratios. Basically, the later transmission took 1st and 2nd way down and 3rd+ down a bit. This gives it more "usable" gearing in stop and go city traffic, but not so for high-speed/high-rev work, especially given the wider spacing between 2nd and 3rd. If you are running even a bit more than stock torque and hp, then the earlier transmission is actually a better choice as it offers closer ratios and still gives you enough off the line grunt. (If you need off the line grunt. Which personally I do not.) For the standard ~200whp modified car, I would argue the earlier transmission is the one you want.
Old Apr 14, 2009 | 06:43 PM
tazio's Avatar
tazio
If you are talking Cooper 5sp then yes, the 05-06 Getrag beats the earlier Midlands hands down.
Old Apr 15, 2009 | 06:09 AM
buzzsaw's Avatar
buzzsaw
note:
Here is a list of used Mini purchase questions we've collected that may help.
Old Apr 15, 2009 | 08:11 AM
Ladidah's Avatar
Ladidah
There's many MINIs in your year range with lower miles on them for sale.
Old Apr 15, 2009 | 11:19 AM
k_h_d's Avatar
k_h_d
2003 MCS with 63,000 miles and no major issues. When I was looking I knew I did not want a 2002. Some say even 2003 models have problems that still need working out but I guess my very late production 2003 had those addressed. I personally would steer clear of any 2002-2006 standard cooper just because of the midlands transmission. I also would not want a CVT because I have read about a lot of problems with those. However any online forum will only have the people with problems posting. If a car works then the owner won't post anything because its suppose to work and thats what is expected.
Old Apr 15, 2009 | 12:55 PM
newusersID's Avatar
newusersID
Thanks guys, great information.
lalroma
20
Apr 2, 2022 06:19 PM
arf88
May 31, 2016 03:07 PM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
