Suspension Rear Camber adjusters, Would you recommend if lowering only
Old Oct 9, 2003 | 06:29 PM
SSMini's Avatar
SSMini
For you guys that lowered your Minis, this question is for you. Im planning on installing a set of springs on my 03 Cooper S. Front will be lowered 1" while the back will be lowered 1.2" My questions is. Do I need the rear camber adjusting rods? How about the front? Is there any problem there in getting it aligned?
Thanks,
Old Oct 10, 2003 | 08:51 AM
CoopingInDC's Avatar
CoopingInDC
i just got the vogtland springs put on. That and a rear sway bar. The car rides great, and doesnt seem to need anything else. Of course, not saying I won't be more stuff...
Danny
Old Oct 10, 2003 | 10:26 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
>>Thanks,
The rear camber adjusting control arms are optional. You can leave the car alone and drive it with negative camber probably you will have about negative 2 degrees to negative 2.4 degrees I would guess. Depends on your other suspension parts and wheels. You can elect to have it aligned at a brake and alignment specialty shop and they can set the rear camber for anything you want. Common settings are negative one degree to negative 1.5 degrees. You can choose. The more agressively you take corners the more negative camber you want in the rear but the more you need to rotate your wheels to not wear them out too quickly- every 3000 miles or so- watch them for wear.
Normal brake shops don't want to do the alignment for a lowered MINI. Brake specialty shops are OK on aligning them.
Front additional suspension parts you don't need. Lowering one inch isn't much.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
