Max tire size?
Old Apr 12, 2009 | 07:42 AM
worksdriver's Avatar
worksdriver
Max tire size?
I'm currently runnnig 215/45 17" tires on my R90 wheels. The wheel has a 7" width. I have JCW suspension so the ride height is only about 1/4" lower than stock.
There seems to be more choice in performance summer tires in 225/45 17" dimensions. Is anyone running tires this size on their MINI? Is it possible to run this size of tire on a 7" wheel or should I go up to 7.5"?
Your thoughts and experiences much appreciated!
Old Apr 12, 2009 | 10:23 AM
Some Guy's Avatar
Some Guy
See sig, that is on the stock S-lites, but that is also the stock ride height. I'll point out that I have never had any rubbing.
Old Apr 12, 2009 | 05:21 PM
worksdriver
Thanks 'Some Guy'. Good to hear you're running them with no issues
Old Apr 12, 2009 | 07:43 PM
Some Guy's Avatar
Some Guy
Keep in mind though that some tires "run wide", so just because mine fit doesnt mean the tire your looking at will fit as well.
Old Apr 12, 2009 | 07:49 PM
lhoboy's Avatar
lhoboy
At 225/45 you are running a much larger diameter than stock. A 225/35 would be more appropriate. I am currently running 215/40s to match the 205/45 stock spec.
Old Apr 13, 2009 | 08:23 AM
Bigshot's Avatar
Bigshot
Do a google for tire size calculator. Some great sites that will show the differences between sizes will come up.
Old Apr 13, 2009 | 09:10 AM
tennis_man's Avatar
tennis_man
Here is a good wheel size calculator. It allows you to put in sizes for two wheels and then compare them side by side:
http://www.wheelsmaster.com/rt_specs.jsp
Old Apr 13, 2009 | 01:24 PM
worksdriver
Thanks, all. Usefull info. I had forgotten that the profile measurement is an aspect ratio %. Therefore a 45 profile on a 205 tire is a lower profile than 45 on a 225 tire.
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
