Navigation & Audio Help with installing SWI-X
Can anyone help me?
I bought the SWI-X adapter and went to go install it and wouldn't you know it, I can't locate the white w/ red strip and yellow dots wire. I've looked at every single wire over and over coming from just behind the steering wheel and I swear it's not there. Anyone else have this problem? Is there another wire I can try?
I have a 2003 JCW S.
Found it, thanks. One more problem now....I got it all hooked up and when I turn it on, the lights just keep flashing. I followed the instructions and whenever I turn it on it just keeps flashing. Any thoughts or do I have a bad unit?
Just make sure the key is off. Press and hold the program button on the swi-x and then turn the key to the on position.
You cut the red/yellow dot wire, correct? You can't splice it you have to cut it then hook the swi-x to the wire that is coming from the steering wheel.
Other than that it's pretty much straight forward.
Dan
Dan
Man do I feel bad. I didn't pay attention to my pic and suggested the wrong wire earlier.
Make sure you got this wire. The one that is pulled down.
Attachment 41201
Attachment 41201
