Rear brakes grabbing sections of rotor?
Old Apr 1, 2009 | 04:10 PM
donjulio's Avatar
donjulio
My LH rear wheel was making this washing machine noise while driving @ all speeds. So I took off and inspected the rotor.
I turn the rotor round and round and about 30% of the rotor gets stuck while spinning between the caliper so I suspect thats where the sound is coming from. My hand brake is off. There doesn't seem to be be warp on the rotor, i used a straight edge.
What else could be wrong?
Old Apr 1, 2009 | 04:19 PM
iwashmycar's Avatar
iwashmycar
you change pads?
Old Apr 1, 2009 | 04:23 PM
donjulio's Avatar
donjulio
Nope, its down to about 1/4 the original thickness.
Old Apr 1, 2009 | 05:19 PM
iwashmycar's Avatar
iwashmycar
hmm people have issues with not 'snapping' the pads onto the piston...maybe they came off because theyre kind of low?
Id pop em out and take a look... maybe recompress the caliper piston all the way back
the whole 30% rubbing with true disks sounds really odd... check the wheel bearings and all that too
Old Apr 1, 2009 | 05:57 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Ditto on what iwashmycar says and also check the Ebrake is releasing at the caliper, that's been an issue for more then a few.
Old Apr 1, 2009 | 06:36 PM
Crashton's Avatar
Crashton
My guess would be the e brake is not releasing all the way. It could be a combination of the e brake & a warped rotor, but it is uncommon to warp a rear rotor. Although I have seen it happen when one comes off the track & parks with the e brake on.
Old Apr 22, 2009 | 09:16 AM
donjulio's Avatar
donjulio
I figured out the problem, its due to hot spots. It happens when your rotors are hot and you leave the ebrake on during park and brake pad "melts" onto the rotor creating non uniform surface.
Now the question is how to remove hot spots?
aldito2
Nov 25, 2015 09:33 PM
gmonde
Sep 8, 2015 06:37 AM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
