H Stock R52 (2008 MC Convertible) camber adjustment
Old Mar 23, 2009 | 11:51 PM
subiedriver's Avatar
subiedriver
I've read a number of posts that refer to removal of an "assembly alignment bolt" or "plastic thingy " that can legally be removed to allow a greater range of allowable stock camber adjustment.
Can anyone tell me (or better yet, show with a pic) where exactly this part is and if it exists on the R52 Convertible chassis?
I'm getting ready to set up my R52 for it's 1st full season of Auto-X and want to get the most out of it.
Would someone be so kind as to describe the exact process of which bolts to loosen and how to apply pressure to reach the max stock limit for camber?
Thanks in advance...
Old Mar 23, 2009 | 11:58 PM
ScottRiqui's Avatar
ScottRiqui
Are you talking about adjusting the camber on the front wheels or the rear? The convertibles don't have any adjustments for camber on the front, and the rear adjustment (only on the '05+ models) is via an eccentric adjuster. I don't think there's anything you can remove or modify to extend the adjustment range on the rear.
Old Mar 24, 2009 | 12:09 AM
subiedriver
I'm asking about Front Camber...
I'm referring to the following quote from this thread:
https://www.northamericanmotoring.co...d.php?t=112054
Originally Posted by jsma
Hi all,
Since I don't have a service manual for my '07 (are they even available?), I was wondering if it was g-stock legal to remove the hex head screw altogether when adjusting camber with the strut tower slots. From Per Schroeder's write-up on Grassroots, it seems like you can, but I just want to be sure so that I don't get protested on it if I don't have the hex head screw in. Thanks for any info.
John
It seems that there is at least *some* natural tolerance that can be taken advantage of. Plus this part on the R53/R56's mentioned above that frees up the natural tolerance some more.
I'm just not sure what I should be looking for or where I would find it...
Thanks for your reply, if you have light to share, shed some on me!
Last edited by subiedriver; Mar 24, 2009 at 12:10 AM. Reason: additional clarification
Old Mar 24, 2009 | 12:17 AM
ScottRiqui's Avatar
ScottRiqui
Well, the first gen cars (R50/R52/R53) don't have strut tower slots for camber adjustment in the front. The holes in the sheetmetal are just about big enough for the three studs on top of the strut to pass through, and not much more.
Here's a picture of my passenger-side strut tower, showing the three nuts that fasten to the strut studs. You can try loosening them and seeing if you can shift the strut a little bit before re-tightening them, but I don't think there's much slop there.
Old Mar 24, 2009 | 06:03 AM
AutoXCooper.com's Avatar
AutoXCooper.com
Hello Subiedriver, The "pin" you are talking about is on the R56/55/57 2nd Gen MINI' not on the 1st Gen R50/52/53's. The only way to get more camber on your R52 is lowering springs and or camber plates or coilovers.
Old Mar 24, 2009 | 06:25 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Exactly correct ^.
Old Mar 24, 2009 | 09:16 AM
subiedriver
Thanks Scott,
That's what I was afraid of...
On a somewhat related subject, is there a specific Haynes (or other service/technical) Manual for the R52 Convertible, or would the R53 book be my best bet?
Old Mar 24, 2009 | 02:45 PM
Mini_Joe's Avatar
Mini_Joe
The Bentley book covers the R50, R52, and R53.
It runs up until 2006... not sure what changes (if any) occurred on the R52 between 2006 and 2008.
So far, everything appears to be identical to the 2006s
Old Mar 24, 2009 | 02:48 PM
BlimeyCabrio
Yep - the Bentley manual has some cabrio-specific content.
BRracing
Dec 22, 2015 09:25 AM
Aug 28, 2015 12:30 PM
Aug 25, 2015 07:11 AM
Minibeagle
Aug 13, 2015 10:00 AM
