Drivetrain Replaced HAI with Alta CAI
Old Mar 16, 2009 | 07:58 PM
Sin MINI's Avatar
Sin MINI
Soon after purchase I (well, a club mate) stripped out the airbox and stuck a K&N filter right on the airbox. Since I did it the same time I put on a 15% pulley, the difference was startling but how much was due to the HAI was unknown.
This weekend the same bud helped install the Alta v2 CAI. Wow, big improvement!
The surprise was how loud the supercharger is. It's common knowledge that it's louder than stock, but given that the HAI was basically straight open at the throttle body and was also very loud, I didn't expect much difference. Boy was I surprised. All I can think of is that the filter is inside the wall now.
Love it, especially since Alta lowered the price $100 and was running a 10% off coupon.
Time for a tune!
Old Mar 16, 2009 | 08:32 PM
Nazrin's Avatar
Nazrin
some say the Alta CAI is actually a HAI too cos, its sucking hot air from the headers
Old Mar 16, 2009 | 09:40 PM
Sin MINI's Avatar
Sin MINI
How so? I didn't see any significant difference bewtween it and others?
Old Mar 16, 2009 | 10:16 PM
sprp85's Avatar
sprp85
HAI isn't as loud as alta because they are located a lil farther away from your window / cabin.
Also, I heard Alta isn't true CAI too...
Old Mar 16, 2009 | 10:55 PM
Nazrin's Avatar
Nazrin
from tests done by our friends in UK, the best intake is the JCW intake with ITG filter...
DDM/m7 intake is also supposed to be very good...
I have the alta V2 CAI (love the sound it makes) and may change to the JCW intake in the future...stay tuned
Old Mar 17, 2009 | 09:59 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
The JCW and Dinan have one thing in common: they are made with a composite (plastic) material. All other CAIs use metal (steel or stainless steel).
Some people believe the steel units heat up (heat soak) and therefore contribute to higher IATs.
My experience and testing suggest that the airbox makes little contribution to rising IATs under normal or high load conditions. So long as you have a nice source of fresh ambient air (front scoop, cowl opening), so long as you don't have hot air entering (seal the air box from engine bay air), and so long as you have a free flowing filter -- clean it often --, then you are doing about all you need to do.
IATs rise because of two things: compression in the SC - which is pretty unavoidable as that's what superchargers do - and heating of intake path components - IC horns, IC, intake manifold. Once the components are hot it doesn't matter what filter you're using...
Bottom line: make a choice of CAI from the list of common alternatives, make sure it's working well, and then fuggedaboudit.
Teh
Aug 22, 2022 04:37 AM
melscoop
Mar 30, 2016 06:56 PM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
