R50/53 Serpentine belt broke!!!
Old Mar 10, 2009 | 06:50 AM
jduplooy's Avatar
jduplooy
Hey guys,
Broke my belt shifting from 2nd to 3rd last night. Luckily I was just around the corner from home, so I managed to get it there before it got too hot.
I already ordered a new belt. Is there something I should check, like maybe something that may have been damaged, or can I just put the new belt on and see how it runs?
BTW I have a 15% pulley
Thanks guys for any ideas
Old Mar 10, 2009 | 07:04 AM
IzzyG's Avatar
IzzyG
I'm guessing you still have your old belt? Take a look and see what might have caused the failure(if there are cracks and wearing down that might have caused it to break). I would also do a once over to make sure nothing was damaged from the whiplash of your belt snapping.
Old Mar 10, 2009 | 07:10 AM
jduplooy's Avatar
jduplooy
It seems to be relatively OK (The Belt) except it looks as if maybe it had some wear on the outside edge. I Have 51000 miles and have had the car since 36000, so I am thinking maybe it was just ready to be changed...
IF something is damaged, What could be damaged? Could it be as bad as the whole supercharger, or not THAT bad?
Old Mar 10, 2009 | 07:12 AM
jduplooy's Avatar
jduplooy
Another thing is that It obviously shot the CEL on...Will changing the belt and starting the car up clear that? or does it need to be cleared?
Old Mar 10, 2009 | 07:32 AM
Bigshot's Avatar
Bigshot
You need to take a close look at the other pulleys for any damage or debris.
The tensioner can actually slam down on the crank pulley and damage it and I have seen where some debris got caught up in the alt pulley and ended up cutting a belt.
Now would be a good time to install a tensioner stop from Minspeed.com or Alta.
The code should reset it self once the car is back to running properly.
Old Mar 10, 2009 | 10:14 AM
Poppa Bear's Avatar
Poppa Bear
This must be the season for broken belts. After checking the condition of the other pulleys, consider this, this or this in order to avoid ~$1000 bill for this!
Cheers!!
Old Mar 11, 2009 | 10:39 AM
jduplooy's Avatar
jduplooy
So I found that my A/C compressor somehow was loose! none of the bolts were in its housing and it was sitting freely in the undercarrage!
This MUST have caused my belt to break.
My car went out of Warrantee last month, but they JUST did the 50,000 mile service and checkup. So I got it towed them and hopefully they will look at it and cover the damage.
My 1 question is that I have a 15% pulley on it. Could they just not honor the warrantee b/c of that or do they still have some kind of liability?
Old Mar 11, 2009 | 01:28 PM
thulchatt's Avatar
thulchatt
Depends on the dealership.
MINI of Nashville, where I went for warranty work, is very mod friendly but others are not. Some depends on what kind of damage. If it is just mounting the compressor and putting on a new belt you could be in luck. If there is major damage they sometimes start looking for reasons not to cover.
Good luck and get your sweet talking in shape.
Old Mar 11, 2009 | 01:32 PM
jduplooy's Avatar
jduplooy
Yeah they are checking it over right now and will let me know what their "technicians" say in the morning.
So fingers crossed
Old Mar 11, 2009 | 04:08 PM
DixonL2's Avatar
DixonL2
There's no way the a/c was loosened to install the pulley, and the dealer should cover the repair unless someone was truly monkeying around in there.
Poppa Bear's dead on: BE SURE TO INSPECT YOUR PULLEYS CAREFULLY! It's easy, as mentioned above, for the tensioner pulley to slam into the crank pulley. The slightest damage will take tiny chunks out of your serpentine belt. Your engine rotates an average of 2500-3000 times per minute. How many thousands of little chunks does it take to destroy a belt? Not many. I've installed several of the retainer cables from Detroit Tuned. They're easy to install (once you've removed the PS wheel and inner fender liner) and a cheap insurance policy.
Good luck and let us know how it turns out!
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
MINI Stupor
Oct 1, 2015 11:36 AM
VanisleRyan
Sep 30, 2015 08:35 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
