Navigation & Audio Factory aux input with an HK Drive + Play
Old Feb 25, 2009 | 12:45 PM
G_Ride's Avatar
G_Ride
I recently installed a HK Drive + Play 1 in my 2004 Mini Cooper S.
The FM modulator succumbs to the same problems as they all do. Therefore, I want to use the AUX in on the head unit. Does anyone use the factory AUX in connector to the line out jack on the D+P?
I know that the Mini’s head unit needs to detect a load before the AUX mode is available, and because a line out does not provide the same level of output as a headphone jack does, I am concerned that the AUX option will not be available after plugging into the D+P's line out.
Old Feb 25, 2009 | 01:09 PM
Edge's Avatar
Edge
AdMINIstrator
It should work just fine. I have the OEM aux input in my MINI... and I can still select the Aux input as a source even when there's nothing plugged into it.
The aux input was designed for and works best with a line out from a device. Using a headphone jack is not ideal in any situation, because that would be double amplification (amplified once from the device, and again in the head unit).
W0TM8
Dec 19, 2019 07:50 AM
surfblue
Oct 24, 2018 01:20 AM
theblackfalcon
Oct 11, 2015 09:49 AM
tippin
Aug 5, 2015 08:43 AM
