R50/53 Steering wheel
Old Feb 19, 2009 | 12:40 PM
moseichuk007's Avatar
moseichuk007
Steering wheel
can a steering wheel with controls be installed in a mini that previously had steering wheel controls? and would the steering wheel controls work with the stock radio?
Old Feb 19, 2009 | 12:50 PM
ClubmanS's Avatar
ClubmanS
Sure you can. I believe everything is pre-wired already but you have to purchase the parts and/or new steering wheel with the MFSW buttons. Some people have switched from 3 spoke to 2 spoke steering wheels and viceversa.
Go to: www.realoem.com to get the part numbers required for the retrofit kits. I would estimate the cost of retrofitting (plus labor) between $700-$1000.
See if this is worth it to you.
Old Feb 19, 2009 | 12:57 PM
moseichuk007
so what you're saying is the all i would have to do is purchase the steering wheel with the buttons like this one? and it should just plug right up?
Old Feb 19, 2009 | 01:24 PM
ClubmanS's Avatar
ClubmanS
Which steering wheel do you have now? 3 or 2 spoker? MFSW buttons or not?
Old Feb 19, 2009 | 01:56 PM
ClubmanS's Avatar
ClubmanS
"Yes" would be my answer.
Old Feb 19, 2009 | 02:55 PM
moseichuk007
its a three spoke wheel, and the only buttons it has are the buttons for the horn.
Old Feb 19, 2009 | 03:18 PM
ClubmanS's Avatar
ClubmanS
I think you can buy the MFSW button inserts for your 3 spoker, that is, if you want to retain it.
Old Feb 19, 2009 | 03:39 PM
chaseabryant's Avatar
chaseabryant
I believe that you are unable to put a multi-function steering wheel in a vehicle that did not originally come with it.
When you put the steering wheel in, there is a spinning wire-harness that the horn, and I am assuming, the multi-function buttons, plug into. If you didn't already have the multi-function buttons in there, there is not a place to plug the control's wires into.
Anybody correct me if I am wrong, however, I do beleive that I remembered properly.
-Chase
Old Feb 19, 2009 | 09:42 PM
moseichuk007
where would you be able to buy the inserts?
Old Feb 19, 2009 | 09:43 PM
moseichuk007
so it doesnt seem like anyone has a definite answer. thanks for the help though.
Old Feb 20, 2009 | 02:49 AM
ClubmanS's Avatar
ClubmanS
Go to www.realoem.com. In there you can see the schematics of the parts and the part numbers. With those in hand you can call the dealer or any MINI/BMW aftermarket OEM parts supplier for pricing and further information. I think you need to do your homework and dig up a little for this one.
Old Jul 20, 2009 | 01:46 PM
htroberts's Avatar
htroberts
RealOEM lists a multi-function retrofit kit:
http://www.realoem.com/bmw/showparts...33&hg=32&fg=95
Old Jul 20, 2009 | 07:19 PM
Mark McCormick's Avatar
Mark McCormick
https://www.northamericanmotoring.co...ailable-3.html
Manny_cooper
Sep 10, 2015 11:09 AM
mdarreen
Sep 2, 2015 10:11 AM
trw92a
Aug 26, 2015 01:47 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
