Engine noise increasing, smoothness fading away
Old Feb 17, 2009 | 11:03 AM
flav's Avatar
flav
my engine has become very loud the last few months. almost making a vibration noise at times. and at 3000-4000 RPMs if i gently let go of the gas the engine seems to make a "im stuck at this gear" noise, it holds it for a few seconds and then sounds drops down. it also likes to cut out on a cold morning at startup when i hit the gas. mine is at 30,000 miles 2007 MCS w/cold air intake, 6 speed manual. i dont mind having a loud engine but its becoming a bad loud. its loosing the smooth sound and feel.
Old Feb 26, 2009 | 06:35 AM
flav's Avatar
flav
i find it hard to believe im the only one that has ever has this problem on here again, its after the car warms up, if i tap the gas around 3000 RPMs there is a weird change in engine sound, like a louder buzzing mechanical engine sound (its coming from the engine). engine was fine until we had a few -15 degree days and now it does this all the time.
Old Feb 26, 2009 | 09:20 AM
danny 1940's Avatar
danny 1940
I'm responding so you don't feel left out of the loop. I am far from an expert on Mini's. When an engine hangs up it could be a number of issues. Have you checked the vacuum lines or checked for an air leak somewhere in the system? Your trottle body could be dirty or you could have an engine management computer going out. There are a number of possible faults. It's very difficult to offer any sound advice without hearing how the motor is acting. Might be time for a trip to the shop. Sorry I could not be more help. Try the vacuum/air leak first. Dan
Old Feb 26, 2009 | 09:21 AM
danny 1940's Avatar
danny 1940
Your only mod is the cold air intake. Has something come loose?
Old Feb 26, 2009 | 11:25 AM
Minidrivr's Avatar
Minidrivr
Bad sound could be a timing chain. There's been some discussion about replacing the chain tensioners in the cold start thread as well.
Old Feb 26, 2009 | 12:41 PM
flav's Avatar
flav
made an appointment for the dealer next week, we'll see what happens.
Old Feb 27, 2009 | 09:57 AM
danny 1940's Avatar
danny 1940
IMHO I think if it is a timing chain, you would hear the noise through out the rev range but more so at low idle/speeds. The chain would not cause the engine to "hang up". Let us know what the dealer says. Dan
Old Mar 27, 2009 | 09:16 AM
SSr56's Avatar
SSr56
any updates? I'm having a similar issue.
Old Mar 29, 2009 | 07:53 PM
flav's Avatar
flav
bad timing chain tensioner. going in in two days to have my engine cracked open and repaired. car sound HORRIBLE right now, but was told no damage was being done. needless to say, im looking at several certified AUDI TT 3.2 DSGs to replace the MINI. we'll see what happens.
Old May 24, 2010 | 08:23 AM
Gooey's Avatar
Gooey
any updates on this?
I'm having the same problem, I think. Is it under warranty?
TREX
Nov 2, 2019 07:31 PM
patrioticmini
Aug 20, 2015 10:54 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
