Rear glass shattered!
Old Feb 10, 2009 | 08:53 AM
second to none's Avatar
second to none
Does anyone know what causes the rear glass to shatter spontaneously? I had nothing in my car, and nothing on the ground, to suggest my window was broken by means of throwing/shooting. Also all of the glass was still in place when I arrived on scene, and I taped it up so it would hold as one piece before it could make a mess of my trunk.
and foil tape FTW
but I should be
Old Feb 10, 2009 | 08:56 AM
ClubmanS's Avatar
ClubmanS
Sudden change in temperature, although very rare. It is not common for glass in the MINI to shatter just like that. BB Gun attack perhaps?
Let the insurance take care of it. At least replacing the hatch glass is no where near as bad as replacing the windshield.
Old Feb 10, 2009 | 08:58 AM
ClubmanS's Avatar
ClubmanS
The glass is still in place because it is tempered safety glass. The actual glass is sandwiched between 2 plastic film layers and pressed on using a special process.
Old Feb 10, 2009 | 09:08 AM
second to none
I suspect it just broke from stress. It wasn't chipped, the defroster worked this morning, and that was about 2 hours before this occurence. It was parked with the rear facing the sun, but the inside and outside temps were equal, so I don't think it was the differential of expansion that did it.
Old Feb 10, 2009 | 09:11 AM
ClubmanS's Avatar
ClubmanS
Here in Florida, insurance providers are obligated to supply $0 deductible glass coverage as driving with broken glass is illegal here. What are your insurance provisions for glass coverage in your home state?
I pressume since you appear to have a 2004 MCS MC40, you are out of warranty.
Old Feb 10, 2009 | 09:19 AM
second to none
Yes, my warranty is up. I havn't called Geico yet, but I do have full coverage. There probably are laws about driving like this, but I am not familiar with them. Given the cars I see on the roads every day, I am not concerned about getting stopped in the situation i'm in. Sometimes I wondor how these cars pass inspection, which I am due for this month!
Since I taped the inside, I could probably get off with removing the x from the back, and it will look like that reflective honda tint
Old Feb 10, 2009 | 09:43 AM
CR&PW&JB's Avatar
CR&PW&JB
Definitely illegal to drive with a shattered rear window in most, if not all, states. You can imagine why.
Call your insurance company. As ClubmanS said, in some jurisdictions, insurance companies waive comp deductibles for glass-only claims. And they may also pay to have the veh towed to a repair shop since it is technically non-driveable.
Old Feb 10, 2009 | 09:50 AM
ClubmanS's Avatar
ClubmanS
Hey CR, how much is the replacement hatch glass for a MINI typically go for?
Old Feb 10, 2009 | 09:58 AM
MINIdave's Avatar
MINIdave
Believe it or not, it was probable the rear def that broke it, have the relay checked before you put in a new one.
When electric rear defrosters first came to this country in the late 60's and early 70's this used to happen a lot.
Old Feb 10, 2009 | 11:02 AM
second to none
So how does that brake it? They just stay on and heat the glass to expand more than the frame which holds it? I will definetly check that before I brake one twice!
Old Feb 10, 2009 | 11:16 AM
CR&PW&JB's Avatar
CR&PW&JB
Beats me, I haven't seen an estimate for one of those. Had a rear-ender involing a MINI about six weeks ago but the glass wasn't broken in that claim.
I'm not an estimator, so I don't have the software on my computer to look it up.
Old Feb 10, 2009 | 12:29 PM
gaffer's Avatar
gaffer
I believe the side windows, back window and moon roof are tempered as to increase strength and break into small ice shaped chunks, and are not a sandwiched laminate. The windshield is annealed (not tempered) and is actually 2 thin windshields sandwiched together with plastic in between to hold it together if broken. Two different processes for two different applications. Who knows what could have caused it to break. I would look for a BB inside the car though.
Old Feb 12, 2009 | 04:55 PM
zminitech's Avatar
zminitech
Yes, only the windshield is layered, all other glass is tempered and will break in small pieces. I second the BB search.
Old Feb 12, 2009 | 05:21 PM
cabwy's Avatar
cabwy
I am voting on the BB gun also. For what that is worth!
Old Feb 12, 2009 | 05:34 PM
Mr. D's Avatar
Mr. D
Bummer, hope your insurance is not a hassle. Where is the bird that ran into the glass?
Old Feb 14, 2009 | 09:52 AM
pmustang's Avatar
pmustang
I wish mine would do that, I destroyed it using an ice scraper!!! looks like someone used a drill with a wire wheel on it. Peter
Old Aug 4, 2009 | 08:08 PM
alicecooper1's Avatar
alicecooper1
shattered rear glass
I had the same thing happen to my mini cooper clubman. It isn't even a year old and there is no evidence of any foul play. It is a defect in the glass. Did mini replace the glass under warranty.
Old Aug 5, 2009 | 12:26 PM
MINIdave's Avatar
MINIdave
No, the car is an '04 model, not MINI's problem..........
One of your barn door windows broke?
emulajavi
Dec 24, 2018 09:15 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
xpunisherx
Aug 10, 2015 10:50 PM
