R50/53 Supercharger/water pump question
Old Feb 1, 2009 | 01:00 PM
JAB 67's Avatar
JAB 67
I'm unclear on how the water pump mounts to the supercharger. In order to remove the supercharger is it necessary to disrupt the cooling system, i.e. drain the coolant? Of does the pump separate from the supercharger, without the need to disconnect any of the coolant hoses? TIA.
Old Feb 1, 2009 | 01:18 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Jump over to this thread...
https://www.northamericanmotoring.co...pump-leak.html
To answer your last question...you can just unbolt the pump from the drive on the back of the supercharger.
Old Feb 1, 2009 | 01:55 PM
Berthil's Avatar
Berthil
Be careful with the sealing ring on the waterpump that goes into engine block, it is easily damaged and you won't notice until you have put everything together and start the engine.
Aug 27, 2015 10:00 PM
patsum
Aug 26, 2015 06:29 AM
coachvminis
Aug 25, 2015 06:58 AM
kpl
Aug 11, 2015 04:52 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
