R50/53 I need a throw-out bearing...
Old Jan 26, 2009 | 02:35 PM
DevilMeTaz's Avatar
DevilMeTaz
I need to replace my throw-out bearing. Apparently, there are only 21 located in the nation, according to 3 different Mini dealerships. Does anyone know an aftermarket supplier I can get one from, fairly quickly? I want to have my Dad replace it this weekend.
Thanks!
Old Jan 26, 2009 | 02:47 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
How many miles are on your clutch? Well, it doesn't really matter. If you are going through the trouble of dropping the transmission, you should replace the whole clutch assembly. They'll give you a throw-out bearing with a new clutch. Stay away from SPEC clutches.
Old Jan 26, 2009 | 03:08 PM
miniconcarne's Avatar
miniconcarne
Pelican Parts. But, may not arrive by weekend.
http://www.pelicanparts.com/euro/cat..._pg1.htm#item1
Old Jan 26, 2009 | 04:32 PM
ItaMamuel's Avatar
ItaMamuel
i have a almost new flywheel,clutch and transmission... and i want to get rid of it .. but....................i'm From portugal.. so no chance i guess
Old Jan 26, 2009 | 04:35 PM
ClubmanS's Avatar
ClubmanS
Try www.clutchmasters.com or www.waymotorworks.com for quality clutch replacement parts. They may be able to hook you up with overnight delivery of parts if available.
Old Jan 26, 2009 | 04:41 PM
ClubmanS's Avatar
ClubmanS
You can also try this company:
http://www.ecstuning.com/stage/edpd/...FQZeswodjnGOUw
Old Jan 26, 2009 | 05:08 PM
CHKMINI's Avatar
CHKMINI
What has brought you to the conclusion that you need a throwout bearing?
Old Jan 26, 2009 | 05:14 PM
lilruffcat's Avatar
lilruffcat
I just had my clutch, flywheel and throwout bearing replaced under warranty... mine is an 06MCS.. might want to check if your still covered
Old Jan 26, 2009 | 07:14 PM
DevilMeTaz's Avatar
DevilMeTaz
I have a 2003 with 85K miles on it. There's no warranty to speak of (unfortunately.)
On Friday, it started making a sound/vibration when I pushed the clutch in and stopped when I released the clutch. I told my dad, (aka my mechanic) and he diagnosed it as the throw out bearing. He seemed to think that I caught the sound early enough that I wouldn't need to drop $$ on a totally new clutch.
I'll try the companies you guys suggested . . .
Old Jan 26, 2009 | 07:26 PM
JAB 67's Avatar
JAB 67
In my opinion, a noisy throw out bearing is not likely to fail any time soon, at least not to the point where the car is undriveable. I can not imagine going to the time and trouble of replacing only the throw out bearing, without also replacing the clutch and possibly the rear main seal too.
Old Jan 26, 2009 | 10:14 PM
DevilMeTaz's Avatar
DevilMeTaz
This may be a silly question . . . What's the rear main seal?
Obviously, it's a good thing I'm not the one doin' the work, but I am the one ordering the parts. It helps to grasp what the part is for. (Though sometimes, I just say the name and hope the guy on the other end knows what the hell I'm talking about!)
Old Jan 26, 2009 | 10:49 PM
k-huevo's Avatar
k-huevo
You can see one here; it won't need replacing unless it is leaking. If the clutch plate is ok, there will be no need to replace that either, but if you don't have a back up, well you're without the MINI until you get one.
Sep 3, 2015 02:06 PM
GumbyLara
Jan 17, 2014 06:10 AM
hegira
Apr 11, 2011 09:24 AM
bobbyharr883
Classic Mini Talk
May 28, 2009 07:25 PM
YYC
Jun 8, 2005 06:24 PM
