Wheel rub in hard right turns
Old Jan 25, 2009 | 10:26 AM
dwf137's Avatar
dwf137
Stock wheels, stock tire size.
I just recently switched to stud-less snow tires, but they're the same size as the stock tires.
In hard right turns(parking lots), My passenger side tire rubs on the fender lining.
Anyone have any similar issues like this?
I'm obviously not too concerned, but stock tire sizes shouldn't be rubbing...
Old Jan 25, 2009 | 10:44 AM
Browser_23's Avatar
Browser_23
Do the rims you have the snow tires on have the same offset as the other rims?
Old Jan 25, 2009 | 12:52 PM
dwf137's Avatar
dwf137
stock rims, i just put the snow tires onto my factory rims(S-winders). They're going to be my snow rims, I'll be buying a summer wheel/tire combo in the spring.
Old Jan 25, 2009 | 01:00 PM
djam43's Avatar
djam43
Sounds like your snow tires are the problem.
Old Jan 25, 2009 | 04:13 PM
dwf137's Avatar
dwf137
They're still the same size as factory though, 195-50-16... I stuck with that specifically because I wanted to be able to fit snow cables if I needed to. I found a set that will fit with factory tire sizes.
I dunno, maybe the tread is thicker on the snows?
And it doesn't happen on hard lefts, only hard rights.
Old Jan 26, 2009 | 12:05 PM
GrnMtnMini's Avatar
GrnMtnMini
Have the exact same problem
Snows nokian hakkapelitta 195-50-5-16 on stock rims
Tires rub when tires turned all the way to the right
Car is going in for numerous issues this week so we'll see what they say
Old Jan 26, 2009 | 12:25 PM
djam43's Avatar
djam43
Yes, the snow tire pattern on that particular brand is most probably the problem.
Old Jan 26, 2009 | 12:53 PM
dwf137's Avatar
dwf137
definitely report back about the rubbing.
I'm not too concerned, it only happens when I'm in parking lots and whatnot, but if it's something that can be changed, I'll be heading to the dealer too.
I've got Dunlop Wintersport 3D's.
Sounds like it must be the tread pattern at the edges. Seems like they might not round as much as the all-seasons at the edges, causing a slight rubbing.
Old Jan 28, 2009 | 08:24 PM
MotorMouth's Avatar
MotorMouth
Let me play Nostradamus.
"Yep, it rubs. Nope those are not OEM tires. Can't help you."
Old Jan 28, 2009 | 10:18 PM
dwf137's Avatar
dwf137
lol...
is there really that much of a difference? it's not like we're using absurdly sized wheels, they're factory size... had they offered a snow tire, I would have gotten one.
Old Feb 19, 2013 | 04:43 AM
mattkosem's Avatar
mattkosem
Sorry for dredging up an old old thread, but I believe I'm experiencing this issue on my car as well. I've had 16" wheels and Blizzak WS70 snow tires in the stock 195/50R16 installed all winter, and noticed yesterday that when making a hard right turn (like cut the wheel at 35 hard) I'm hearing some rubbing. I took a peek in the wheel well, and see evidence of the tire touching the furry plastic stuff inside the wheel well. Or so it seems at least, I see a distinct roughed up area in the location that would be likely to see this in there. It's not on the passenger side though, but the driver's side.
Is this a common issue with floppy snow tires on small wheels on these cars?
--Matt
woodstudio
Mar 15, 2020 08:28 AM
SosoMINI
Nov 22, 2015 03:17 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Dashdog
Aug 10, 2015 06:17 AM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
