Spot/Driving lights-preferences?
Old Jan 21, 2009 | 01:28 PM
tr6drvr's Avatar
tr6drvr
I'd like to intall a set of 4 spot/driving lights on my newly acquried classic Mini. NE season prevents me from seeign a variety other's setups live so I am hoping to get some opinions here as I am too anxious to get going on mods to wait for springtime . I prefer the appearance of the raised middle two lights, but am not married to the idea if there aren't any sturdy quality bars/sets available at reasonable prices. Sooo, I am looking for opinions on light brands, appearance, bar vs no bar, raised vs "works" look, etc.
Thanks!
Old Jan 21, 2009 | 02:57 PM
mk1leg's Avatar
mk1leg
well its your choice I have 4 in a row middle 2 slightly higher............this wiring diagram may help you ....................
Old Jan 21, 2009 | 05:00 PM
tr6drvr's Avatar
tr6drvr
Excellent diagram-I will use that if I do 2X2. How did you mount? Full width bracket?
Old Jan 22, 2009 | 09:30 AM
elprofe's Avatar
elprofe
this place sells a custom made one that bolts to the subframe.....really nice!
www.heritagegarage.com
Old Jan 24, 2009 | 08:34 AM
tr6drvr's Avatar
tr6drvr
Thanks! Looks good on site. Not cheap, but nice.
Old Jan 24, 2009 | 09:24 AM
elprofe's Avatar
elprofe
not cheap, but different.....plus it's stainless steel so it'll probably outlast some chrome UK stuff.
Old Jan 25, 2009 | 09:05 AM
tr6drvr's Avatar
tr6drvr
How does it mount? I see they say it attaches using subframe bolts and then what, does it curve up behind the front bumper and then does the cross member sit within the bumper cave or above it?
Old Jan 25, 2009 | 10:54 AM
elprofe's Avatar
elprofe
curves up to be just infront of the bumper.
bolt on by removing the bolts that attach the front apron to subframe.
Old Jan 25, 2009 | 10:58 AM
elprofe's Avatar
elprofe
if you email of call them, they can provide you a pic of it mounted on a car with lights.
Old Jan 26, 2009 | 08:33 AM
tr6drvr's Avatar
tr6drvr
Thanks, and I will give them a call for a pic.
Old Jan 26, 2009 | 10:43 AM
elprofe's Avatar
elprofe
you are looking fro something cheaper....you can get a complete bar with lights for that much from gbcarparts.com
Old Jan 26, 2009 | 03:57 PM
Classic Blimey's Avatar
Classic Blimey
Thats the set up I have.Wipac. I like them but had to make my own bracing to mount them at the top to keep them from vibrating when driving.
I used a 4 pole trailer connector so I could detach them when removing the grill.
Old Jan 26, 2009 | 04:21 PM
elprofe's Avatar
elprofe
that's a good idea to make them removal....you they are going on a 70 or newer there is a grill with built in lights as well.
Old Jan 27, 2009 | 07:25 AM
tr6drvr's Avatar
tr6drvr
Your S is a BEAUTY! ( I like the snow-globe artistry too)
I've been looking at the WIPAC or similar setup too as I like the raised center light appearance. The bracket seems flimsy. How did you do the bracket bracing? Do I see a bar screwed into the backs of all 4 lights?
Old Jan 27, 2009 | 03:55 PM
Classic Blimey
Thanks for the kind words.
Yes I made a flate alum bar that I pop riveted to the back of each light.This bar is then tied in to the grill.No shake.
Old Jan 28, 2009 | 07:08 AM
tr6drvr's Avatar
tr6drvr
Nicely done! Not sure I have the talent to pull that off.
Old Jan 28, 2009 | 11:33 AM
MtyMous's Avatar
MtyMous
That's pretty much exactly what I'm planning on doing to mine.
Old Jan 28, 2009 | 01:32 PM
elprofe's Avatar
elprofe
I would like to see detailed pics of such bar. thx
Old Jan 28, 2009 | 05:52 PM
Classic Blimey
Any particualer pics?
Old Jan 28, 2009 | 05:55 PM
Classic Blimey
Not hard at all.It only takes a drill,pop rivet gun, 1/2 flat stock and exactly 3 Sam Adams beers.....4 if it is a hot day and your friend helps.
Old Jan 28, 2009 | 07:43 PM
elprofe's Avatar
elprofe
thanks....i see what you did....i guess the pics are not visible at work.
Old Jan 29, 2009 | 08:56 AM
tr6drvr's Avatar
tr6drvr
Aluminum stock it looks to be. Alignment must be a bear given the fixed covers ( if one uses the covers).
1 Sam for my friend? I have no such friends.
Old Jan 29, 2009 | 04:31 PM
Classic Blimey
Let your friends get thsir own beer. Yes it is aluminum.
Old Jan 30, 2009 | 03:47 AM
Big Norm's Avatar
Big Norm
here is a pic of my old set up.....sure helped with visibility..lol
Old Jan 30, 2009 | 06:12 AM
qskapunk's Avatar
qskapunk
might have to make one of those aluminum support bars
I think I might make an individual bar for each light that curves up from the mount beneath each light
will definitely use the trailer connector idea, i have my lights mounted but not wired yet
