R50/53 Window Alignment - Help!
Old Jan 18, 2009 | 09:41 AM
bmwg84's Avatar
bmwg84
Someone broke into my Mini about 1 month ago for a window mount navigation pod.. I had the window replaced "professionally", and now I am getting the sound of wind blowing from this side of the car. I am assuming the glass is not aligned properly. Can someone PLEASE send me directions on how to align this glass so it seals properly!??
PICTURES HELP!!
Old Jan 18, 2009 | 10:13 AM
ClubmanS's Avatar
ClubmanS
Open the door and then get on your knees......
Look way under the metal door and you'll see a couple of screws. Those screws allow you to align the window in the frame. Not sure exactly the adjustment routine, but go easy on turning them.
Hope this helps.
Old Jan 18, 2009 | 12:14 PM
hegira's Avatar
hegira
Don't know whether this will help or not....
http://www.realoem.com/bmw/showparts...71&hg=51&fg=10
Old Jan 18, 2009 | 12:51 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
You loosen the bolts under the door, after it is loose, keep the box wrench on the bolt so that you can slide it forward or back.
edit: mine are bolts, others might be screws...but my car has been in so many accidents that the body shops might have replaced them with bolts - so it would be easier to adjust later...
USNAE2
16
Jun 17, 2022 07:17 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
rt808
Sep 25, 2015 01:59 PM
