R50/53 Lower radiator hose
Old Jan 4, 2009 | 02:04 PM
oliverm's Avatar
oliverm
Lower radiator hose
I want to replace the coolant, '04 MC40, and was wondering do I need to lift the vehicle to loosen the lower radiator hose?
Old Jan 4, 2009 | 02:07 PM
not-so-rednwhitecooper
Its easier to unbolt the modular front end and slide it forward to get at that hose, but you could probably do it if you took the tray off the bottom and used some needle nose pliers.
Old Jan 4, 2009 | 02:22 PM
Professor's Avatar
Professor
So we have no coolant drain?
Old Jan 4, 2009 | 02:35 PM
kapps's Avatar
kapps
Nope. There is one on the engine but it's behind the starter and not accessible. When you do a coolant change, your only going to be replacing about 50% of the coolant. The rest will be stuck in the block.
Old Jan 4, 2009 | 03:00 PM
Eric_Rowland's Avatar
Eric_Rowland
You'd think in a $20K car they could have sprung for a radiator stopcock.
Old Jan 4, 2009 | 03:53 PM
You can flush the block if you just take off the upper radiator hose, put a hose in the coolant bottle and let the motor warm up. Once the coolant comes out clear (no more antifreeze in the block) drain the radiator, fill it up with 100% antifreeze and you are damn near your 50/50 mix.
Old Jan 4, 2009 | 04:10 PM
oliverm's Avatar
oliverm
Great idea for the flushing, thanks. Now how do I drain the radiator?
Old Jan 4, 2009 | 04:40 PM
Eric_Rowland
Note: Some of us live in areas with hard water - I wouldn't *think* of putting tap water in my engine. All those minerals will surely adhere to engine internals.
Old Jan 4, 2009 | 04:44 PM
kapps's Avatar
kapps
Unclip the lower radiator hose.
As for the hose idea, I'm not to keen to letting regular hose water in my cooling system. Distilled water is recommended for a reason. I just drain and refill the coolant once every year or so. That way, there's mostly fresh coolant in the engine at all times.
Old Jan 4, 2009 | 05:00 PM
In a perfect world distilled water is important, unfortunately, we don't live in a perfect world.
The procedure I described above is used in dealerships for cooling system flushes.
Old Jan 4, 2009 | 05:22 PM
Eric_Rowland
Yeah, if I'm feeling **** I'll run a couple of gallons of distilled through it, then refill with coolant. Tougher to do without a stopcock.
Another reason not to go to the stealership for service!
I thought they had fancy machines these days to keep the ethyl glycol from being released into the environment. Maybe it's just in CA.
Old Jan 4, 2009 | 05:32 PM
Used coolant is still treated as oil is as far as bio hazards are handled.
It has to be put into a special container outside right next to the oil, but its still drained like normal, so fancy procedures for draining coolant, except you cant flush it down the floor drain. Spills have to be picked up with oil dry or something similar.
Even though distilled water is the best, you are going to get water with minerals you don't want into the cooling system in one way or another. As long as you flush the coolant according to the proper service intervals, it shouldn't be a problem.
Flat rate for a cooling system flush doesn't pay enough to drain it thoroughly and replace it all with distilled water and coolant.
Old Jan 4, 2009 | 06:33 PM
oliverm's Avatar
oliverm
From what I understand you have to take the front of the car off to get to the hose.
I understand of how to flush the system so you get clear what coming out the top of the radiator, but how do you drain the radiator so you can put in your antifreeze? Am I going to haveto take the front of the car(front clip) off to get to the lower radiator?
If so, then it doesn't pay for me to spend all day doing bodywork just to drain the radiator, and whose to say, since I am not a body man, that I won't break some clip or something else, and then it ends up costing three times as much
Old Jan 4, 2009 | 06:35 PM
yellowbritishrocket's Avatar
yellowbritishrocket
with all the engineering they did with the mini it would have made sense to put a stopcock in the radiator or something...i mean hell honda has done that for years....i just think its rather retarded that the only way to drain the coolant out is to completely dissasemble the front end and remove the lower hose....had to do it once...really hope to not do it again
Old Jan 4, 2009 | 07:05 PM
kapps's Avatar
kapps
You don't have to take the front end off. Jack up the front end, slide yourself under the drivers side and look up. Lower radiator hose is right there. Use some needle nose pliers to squeeze the spring clip and move it up on the hose so you can pull it off the radiator. when everything has drained out, slip the hose back on and slide the spring clip back near the end of the hose with the pliers. I've done it twice.
Old Jan 4, 2009 | 07:22 PM
Eric_Rowland
Ah! Good info, kapp. Thanks - I need to flush mine.
Old Jan 5, 2009 | 07:21 AM
oliverm's Avatar
oliverm
Just what I wanted to hear, great. Looks like I will be getting some antifreeze this weekend.
I am wondering if it is possible to create a hole for a stopcock at the bottom of the radiator?
Old Apr 19, 2009 | 11:29 PM
MiniKJ's Avatar
MiniKJ
flushing and chainging to silicone hoses
Hi there:
My 06 is coming up the 4th year and a flush is due. I do want to change out the plastic hoses with silicone at the same time. Has anyone used silicone hoses with positive result?
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
smdmini
Oct 7, 2019 06:05 AM
makg
Sep 10, 2015 11:59 AM
eliseo1981
Sep 4, 2015 02:33 PM
