Drivetrain B&M 45131 Short Shift Kit
Old Jan 1, 2009 | 01:47 PM
purplehaze05mcs's Avatar
purplehaze05mcs
Any feedback on this? Pros/Cons? Got one but have not installed yet. Is it worth the time? Can't find any previous posts.
Old Jan 1, 2009 | 01:58 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I like mine - Best MOD for the buck.
I put mine in back in June. Best bang for the buck. Puchased off ebay new from store on a $35.00 bid......
Nice thing about it is that the lower dust cover fits when installed, unlike many other aftermarket SSK's.
There are no Cons I have with this product.
Old Jan 1, 2009 | 02:02 PM
purplehaze05mcs
Thanks for the quick info, G Ray. Was the original stick height maintained.
Old Jan 1, 2009 | 02:13 PM
-=gRaY rAvEn=-
Moderator
Here is picture Installed
Here is interior picture of it installed. The orig height is dropped just over an inch I'd say
Old Jan 1, 2009 | 03:49 PM
miniconcarne's Avatar
miniconcarne
+2. I really like my B&M shifter! No cons from my perspective.
Old Jan 1, 2009 | 10:33 PM
drsilvermini's Avatar
drsilvermini
+3 I love my B&M, nice precise short throws, nothing to complain about.
Old Jan 2, 2009 | 06:17 AM
PoonRacing's Avatar
PoonRacing
+4, B&M
Old Jan 3, 2009 | 08:52 AM
cecilcohen's Avatar
cecilcohen
SIICCCCCCCCCCCCCCCCCKKKKK
Old Jan 3, 2009 | 09:09 AM
MoxieMini's Avatar
MoxieMini
I really liked my Alta SSK, personally.
PS - the adjustability (<- is that a word?) is really nice.
Old Jan 3, 2009 | 11:02 AM
mach schnell's Avatar
mach schnell
i think the advantage of the b&m is the metal bushings that replace the oem. i have the cravenspeed, which is also adjustable - for newbies that translates into 2 things - 1) you can adjust the height of the shift **** and that height adjustment then 2) shortens the throw between gears (ie, lower height, shorter throw). but, it uses the stock bushings, so there is still some play which means you do shorten the throw but the overall feel of the shift is still kind of sloppy. in a previous porsche i installed a schnell ssk and it replaced the oem bushings with metal and the end result was a very smooth, tight, short throw - it was orgasmic!!!!!!
my goal - find b&m or ebay knock off bushings (for an 05 - ebay seems to only sell 02-03) to retrofit in with my cravenspeed. that with a tsw engine damper and i may just drive around all day shifting gears!!!!!!
Old Jan 3, 2009 | 11:56 AM
purplehaze05mcs
Cecil,
At first glance, I thought that was a "U" after the "S". =(
Old Jan 14, 2009 | 02:29 AM
mem1220's Avatar
mem1220
be careful when removing the lower shift cable on the bottom of the stock shifter. Mine got bound up and when i did get it off it broke the shifter cable linkage. Took the third cable from mini to replace. It was a bear but it does shift good and im glad i did install but was costly install.
Old Jan 14, 2009 | 04:59 AM
firenewt's Avatar
firenewt
+5 on the B&M. When installing the kit, make sure the shifter cables are are still attached to the clips midway up the undercarriage. Each cable has a rubber grommit that keeps the cable housing from flexing. On my MCS both were not attached - cable housing moved before the cable moved.
Old Jan 14, 2009 | 07:15 PM
thebillsman's Avatar
thebillsman
+6 LOVE my B&M because the stock shifter felt like it was going to break in half when i threw it into 3rd.. the B&M feels very solid to say the least and the shifter height is perfect.. i recommend getting a new shift **** because with the stock **** its very low and can be a very heavy shift, so you'll need some muscle to through it around.. i got a UUC RK3, awesome setup.
Old Jan 21, 2009 | 01:16 PM
SeanKidd's Avatar
SeanKidd
Dont want to hijack, but my '03 MCS Cables freeze up every morning, and I need to replace them with upgraded cables (better end seals?) Are these cables accessible, during the SSK install? recommend both?
Old Jan 22, 2009 | 08:21 AM
Bigshot's Avatar
Bigshot
There is a TSB for the freezing shift cables. Complain to your dealer and they should fix it under warranty.
Old Dec 22, 2009 | 09:59 AM
HoustonCoog's Avatar
HoustonCoog
Does anyone have a link to an ebay store for this at the $35 price? All I can find is the B&M45129 shift kit; which I would be okay with but I am unsure if it will fit on '04 Cooper S. Does anyone know if the 45129 kit will fit an 04' MCS?
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
jziran
Aug 24, 2015 04:50 PM
