R56 Need extra paint
Old Dec 24, 2008 | 11:22 PM
Dwell's Avatar
Dwell
Need extra paint
Sorry if this has been covered, but where can I buy Pepper White extra paint (not touch up paint)? Is there a Mini website that sells this, or anyone know?
Thanks in advance.
Old Dec 25, 2008 | 06:35 AM
oldchicago's Avatar
oldchicago
Any Automotive Paint supplier should be able to mix it for you by the paint code, be advised there are variations to the actual code so you may want to bring the paint supplier a paint piece of the car ie. fuel door to properly match the color. Also stay with the chemicals used by the paint manufacturers line ie. Hardeners, Reducers, Primers, Sealers and Clearcoats. should be smae brand/line to avoid any problems. I would also stick with a known brand name such as BASF weather Glasurit or Diamond, PPG or Dupont. We shoot BASF Diamont where I work and the color match is very good when panel painting components but as always the best refinish work is blended into adjacent panels. Hope this helps - Mark
Old Dec 25, 2008 | 08:16 AM
COOP310's Avatar
COOP310
Try this
http://www.minspeed.net/R56SP.htm
I ordered Indi Blue from them before and it was a perfect match.
Old Dec 25, 2008 | 08:58 AM
Red Bull's Avatar
Red Bull
Thanks in advance.
If you want paint to spray go to an auto body supply house. We are a custom paint shop and spray Mini colors and Corvette colors. We use PPG Deltron 2000 series paint. The match is some of the best I have ever used. You can also buy in in a pint. You can get your paint code from the car or call the dealer.
Old Dec 25, 2008 | 11:47 AM
Dwell's Avatar
Dwell
Originally Posted by COOP310
Try this
you rock. exactly what i was going for.
thanks a lot bud.
Old Aug 13, 2010 | 03:41 PM
corin.mcblide's Avatar
corin.mcblide
now that minispeed is gone, anyone know where i can get that same stuff?
Old Aug 13, 2010 | 04:28 PM
Capt_bj's Avatar
Capt_bj
All you need is the factory paint code
and then you can go to your local auto paint supplier - if you want bulk paint (AKA paint to come out of the end of a spray gun.) and they can mix it 4 u. Check the yellow pages under automotive paint. Any supplier can match the color given the code....
If you want small quantity or a rattle can you can use
http://www.automotivetouchup.com/
need paint codes
http://www.sunshineminis.org/forums/...p?f=39&t=16182
Old Aug 13, 2010 | 05:05 PM
krishnika's Avatar
krishnika
Originally Posted by Capt_bj
What about interior colors? - (i.e. anthracite that's on the down tubes) Is there a chart for those? thanks.
Old Aug 13, 2010 | 05:45 PM
corin.mcblide
thanks capt'n!!!
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
