I need longer lug bolts
Old Dec 8, 2008 | 12:27 AM
MUShadd's Avatar
MUShadd
I am having trouble finding what size lug bolt i should get to run 8mm spacers. I believe the factory size is m12x1.5? is the oem length 28mm or something else? I have found this information on new MINIs but not my for my 04.
My guess is I need M12x1.5-33mm?
Also is our lugs cone or ball seat?
Old Dec 8, 2008 | 05:31 AM
AutoXCooper.com's Avatar
AutoXCooper.com
This kit will work with your 8mm spacers, http://www.autoxcooper.com/tsw_stud_kits.html
Old Dec 8, 2008 | 07:34 AM
Bigshot's Avatar
Bigshot
Go for the stud kit !
Old Dec 8, 2008 | 07:45 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Depends on your wheel...but more than likely they are conical.
Old Dec 9, 2008 | 06:29 AM
MUShadd's Avatar
MUShadd
how safe are studs? Everywhere I go refuses to install them due to liability issues. Sure its simple to put them in myself, but it just makes me question.
Old Dec 9, 2008 | 06:49 AM
BlimeyCabrio's Avatar
BlimeyCabrio
LOTS of track MINIs running studs.... if they were going to fail, they'd fail under those conditions, I think.
That said, it IS one more thing you need to keep an eye on... to make sure they're installed properly and don't back out...
Old Dec 9, 2008 | 07:22 AM
Bigshot's Avatar
Bigshot
One word.....Red Loctite.
Old Dec 9, 2008 | 07:41 AM
jimz68's Avatar
jimz68
That's actually two words...
Anyway, I have over 150K miles including a few track days on my studs and have had no problems.
Like Bigshot said, "Red Loctite".
Jim
Old Feb 17, 2009 | 11:26 PM
nots0_mini's Avatar
nots0_mini
just cuz i'm a noob when it comes to euro cars and the lug bolts..
is it necessary to get new, longer lug bolts everytime you swap wheels?
like do the lengths of the bolts depend on the wheel itself?
are studs the better way to go?
Old Feb 18, 2009 | 12:25 AM
xnotfunkylex's Avatar
xnotfunkylex
Shadd needs new bolts because he is going to be using spacers, which means that his bolts will be too short.
Old Feb 18, 2009 | 12:55 AM
nots0_mini's Avatar
nots0_mini
^^ do the OEM lug bolts fit on most aftermarket wheels?
cuz i remember trying to fit rims on an 08 MCS, and the oem conical lug bolts weren't long enough to reach the axle, sans the spacers
Old Feb 18, 2009 | 10:24 AM
grodenglaive's Avatar
grodenglaive
no, they don't fit a lot of rims because they are 14 mm diameter (2007+ MINIs) and many wheels are designed for a 12 mm bolt only (the holes are too small). Also (and this was my problem) the bolts have big heads on them and some rims (especially multi-fit rims) require a narrow headed bolt (often called tuner lugs). To make matters worse, there is only one company that makes tuner lug bolts in the 14x1.25 size for the new MINI - Palo Uber - and they are really expensive and they rust.
This is another reason to get a stud kit, but if you are carefull about which rims you buy you can stick with the OEM bolts. Tirerack is good that way - if you select your specific vehicle, the website will only recomend wheels that fit.
Old Feb 18, 2009 | 10:40 AM
Rally@StanceDesign
There are other companies that make them. I found some on ebay pretty easily.
patsum
26
May 29, 2021 06:29 PM
StrongIslandMini
Sep 16, 2015 12:58 AM
Sep 10, 2015 10:52 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
