02 MCS Battery light on and Power steering doesn't work????
Old Nov 26, 2008 | 01:01 PM
diamondwon's Avatar
diamondwon
I have replaced the alternator and had the battery tested ok. 11.8 volts @ the battery with car running or not. That is why i replaced the alternator. Reassembled car and started with the same problem. Battey light on and no power steering. Any help?
Old Nov 26, 2008 | 01:09 PM
#20Works4me's Avatar
#20Works4me
Voltage regulator?
Old Nov 26, 2008 | 01:23 PM
diamondwon's Avatar
diamondwon
No mention of voltage regulator in shop manual
Old Nov 26, 2008 | 01:29 PM
Berthil's Avatar
Berthil
Alternator belt snapped. Don't drive, no water cooling either.
Old Nov 26, 2008 | 04:18 PM
diamondwon's Avatar
diamondwon
no not anythig easy like that. I have replaced the alternator and the supercharger while i was in there. New belt new Alternator. Battery has been tested @ the auto parts store, Battery OK!
Old Nov 26, 2008 | 05:36 PM
healey67's Avatar
healey67
check my other post on the chat..... Sounds to me like your crank pulley may have seperated. I would definitely check that out
Old Nov 26, 2008 | 05:38 PM
Rich.Wolfson's Avatar
Rich.Wolfson
The battery should read 13.2 volts (2.2 volts per cell) not 11.8 and should not be the same running and not.
Have someone else test the battery.
Rich
Old Nov 26, 2008 | 06:06 PM
kapps's Avatar
kapps
Yeah, anything under 12.5 with the car off and the battery is on it's way out. A new battery will read 12.8-13V. With the car on, it should be closer to 14V.
Old Dec 1, 2008 | 07:17 PM
diamondwon's Avatar
diamondwon
found the problem! The rebuilt alternator was bad from the vendor.
Getrieben
Sep 12, 2024 07:03 AM
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
xraycat
Aug 12, 2015 02:36 PM
nismo4life
Aug 5, 2015 08:31 AM
