R56 Someone please test this?
Old Nov 23, 2008 | 12:53 PM
Apple's Avatar
Apple
On a mini without comfort access, take the key out and within 10 second press the start button?
Does it start and run?
Old Nov 23, 2008 | 01:22 PM
DanF's Avatar
DanF
Yes it does.
Old Nov 23, 2008 | 01:25 PM
tambi's Avatar
tambi
Turn engine off > take key out > 2 seconds later pressed the start/stop button twice (with brakes & clutch depressed) -->
I could get just the ignition to go on - but couldn't crank the engine
Old Nov 23, 2008 | 01:34 PM
Btwyx's Avatar
Btwyx
It works for me in Tristan, I'm not sure about Shawn.
Old Nov 23, 2008 | 01:39 PM
pilotart's Avatar
pilotart
Mine starts, if you have a foot on the brake w/auto in Park or Neutral.
Old Nov 23, 2008 | 01:42 PM
Apple's Avatar
Apple
Ok my BMW does the same and you can drive with it like that, just want to know, when i order my New apple. you only need to press it once .
Old Nov 23, 2008 | 01:59 PM
Apple's Avatar
Apple
push once!
Old Nov 24, 2008 | 08:06 AM
Apple's Avatar
Apple
bump...
Old Nov 24, 2008 | 08:19 AM
clayvt's Avatar
clayvt
Tried it last night and it indeed does work. but to fully shut it off i needed to push the button twice.
Old Nov 24, 2008 | 10:23 AM
bearcat245's Avatar
bearcat245
Yep....on automatics press break and start button once. Twice to stop.
Old Nov 24, 2008 | 10:39 AM
futuremini's Avatar
futuremini
You can also hold the start/stop button down for a longer period and it will turn everything off just by pushing it once.
Old Nov 24, 2008 | 11:05 AM
ChrisTKD's Avatar
ChrisTKD
Dumb question - why do you want to do this?
Old Nov 24, 2008 | 11:08 AM
Apple's Avatar
Apple
sometimes my CC is on my key chain, i need it at the window, I am building a new Mini, and just wanted to see if it was like my BMW... and no question is dumb...
Old Nov 24, 2008 | 11:14 AM
Flyinace2000's Avatar
Flyinace2000
If i recall this also works on no comforat access cars.
1. Car running
2. Press Button and remove key (car is stopped)
3. Clutch in and press button, car starts (no key) as long as i don't open a door.
Old Nov 24, 2008 | 12:36 PM
MeloR56's Avatar
MeloR56
Nope... remove key (fob) and press start button... nothing; remove key and press clutch in and press start button...nothing; remove key and press clutch in and press on brake and press start button...nothing.
I have a 08 MCS manual tranny
Michael
Old Nov 24, 2008 | 01:06 PM
pilotart's Avatar
pilotart
MCa without Comfort Access; Engine running xmisson in Park, press [start] engine turns off and remove Key/Fob.
Before opening door, foot on brake and press [start] and engine starts, you can now leave the car with engine running and Key/Fob in your hand.
Expect that there is a time limit (seconds) allowed for the re-start and you are likely not able to repeat before inserting Key/Fob again,
so don't drive away without it.
Old Nov 25, 2008 | 04:10 PM
e30r56's Avatar
e30r56
Works on my 6/07 mcs non-comfort assist. That's pretty nifty. Would be a decently safe way to get it warmed up in the cold.
Apple, you know you could just remove the solid key from the fob to get to anything on the chain. It would save a little wear and tear as you don't have to shut the car off and then start it again.
Doc Pain
Mar 10, 2021 04:50 AM
jennster
Sep 28, 2015 06:19 PM
silence2-38554
Sep 28, 2015 12:19 PM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
