Navigation & Audio Replacing H/K Amplifier
Old Nov 23, 2008 | 11:15 AM
jayxx83's Avatar
jayxx83
Been lucky and able to pick up two fully working H/K amplifiers for £200.
I just wanted to know how to replace this. Some are saying you have to take the rear seats out then remove the rear panel, others say you can get it out by removing the side panel.
Looking at the bracket there are only two 10mm bolts securing the amp to the car chassis. What is this screw with a phillips head people refer to that you need to access via the boot light.
Does anyone have any pictures that may be able to assist me.
Thanks in advance.
Old Nov 23, 2008 | 02:20 PM
GBMINI's Avatar
GBMINI
The H/K amp mounted to it's bracket is fastened to the car in three places. A nut on bolt bottom right, that you can see through the side panel opening; and also two screws, one top right and one top left. Not sure you could reach both of them without removing the rear panel - but removing the seats and rear panel is not that hard!
Ignore the electronics - this is the H/K bracket:
Old Nov 25, 2008 | 02:43 PM
jayxx83's Avatar
jayxx83
cheers dude. where are the screws located for the rear panel removal. do you need to remove the rear qtr card where the speaker is located also?
Old Nov 25, 2008 | 02:47 PM
GBMINI's Avatar
GBMINI
The side panel is a single piece from rear edge of (front) door, to hatch!
MINI2 has a how-to on removing the interior (go down to "Removal of the rear seats is required to install new rear speakers")
Old Nov 25, 2008 | 02:57 PM
jayxx83's Avatar
jayxx83
thanks v much matey.
Getrieben
Sep 12, 2024 07:03 AM
Getrieben
Aug 17, 2016 06:32 AM
yashmack
Aug 15, 2015 03:11 PM
Emnotek
Aug 13, 2015 05:47 PM
CARdiac
Aug 8, 2015 03:30 PM
