helicoil tang removal help
Old Nov 11, 2008 | 10:09 AM
chorline's Avatar
chorline
Just installed a helicoil in my blown spark plug hole and all seems to be fit and snug. Just cannot get the tang removed. I've been everywhere looking for a long set of needle nose pliers but no dice on finding them as long as I need. Any advise recommendations would be greatly appreciated. Thanks in advance
Old Nov 11, 2008 | 10:38 AM
daflake's Avatar
daflake
If you did the coil with the head in place you should have gone with a backtap instead. You could try to break it with a screw driver and then use a magnet to get it out. However, I would remove the head instead.
Old Nov 11, 2008 | 10:59 AM
chorline's Avatar
chorline
got it. chaulk it up to luck or what have you but I used some thin metal 'rope' I had around the house and looped the tang. Then used some greese to put a small coat in the plug hole.. pulled up on the metal rope and it snapped right up and stuck to the greese in the hole. then used a long magnet I had to grab and toss it out. Phew.. what a fun time. false alarm I guess but thanks so much 'daflake' for your quick response. I did try the backtap method but the hole seemed to be too stripped, The helicoil worked great and hopefully the end result is good as well. thanks again!!
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
