MCSa problem/ big problem?
Old Nov 6, 2008 | 01:43 PM
everytimeidie027's Avatar
everytimeidie027
so i was on the freeway yesterday, and was stuck in traffic, the car ahead of me scoots up. so I do too, but when i pressed the accelerator, the engine just revved, and i was just moving forward off of momentum. I tried sticking it into SD, and nothing. the engine just kept reving without moving. I signal to pull over, and the car starts to get power though. The accelerator works again, but the engine has no pull, almost as if i didnt even have a supercharger, it was really sluggish. so I pull off the freeway, because i can barely keep up with the speeds, as traffic starts to break up. so i open my bonnet, and everythings in place, the belt, intake filter, and all the wires. start the car, and everything is back to normal...
do you guys think its just a hiccup? or should i have it checked out?
Old Nov 6, 2008 | 04:14 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
It wouldn't hurt to have some mechanic with a fancy computer scanner to look at it. Even if the car didn't throw a code, there still might be a record of what happened in the computer. I'm about 75% sure of this.
Old Nov 6, 2008 | 04:49 PM
PenelopeG3's Avatar
PenelopeG3
scary. i have an 06 MCSa also. I'd be making an appt at the dealer if it were me.
Old Nov 6, 2008 | 04:59 PM
Camthewookie's Avatar
Camthewookie
I've not had this problem in my 06 MCSa, but have had it stall once or twice at very low speeds in parking lots. Let us know what you find out, so we might know what to look out for.
Old Nov 6, 2008 | 08:50 PM
everytimeidie027
well I drove to LA from my house (a good 1 1/2 hour drive), and everything seems fine, but I'm thinking of scheduling an appt with my dealer to see what happened yesterday
Old Nov 6, 2008 | 09:04 PM
Eurothrasher's Avatar
Eurothrasher
My Jag did this to me two years ago. Dealer picked it up and towed it to Hanover, about 70 miles away on their dime.....Turned out the computer put the car into what is called "limp mode". If the cars computer detects an issue with the transmission or braking system, it automatically cuts engine power only giving you enough to pull of the roadway and call for help.
In my case with the jag, it was a bad rear caliper spring/ebrake issue. Mechanic said that sometimes these matters rectify themselves just by shutting the car off for a few minutes. But since it was 20 degrees outside and I was off the Interstate, and not knowing how long I was going to wait for help, I opted not to shut her down.....
I was told many European Automobiles have this feature, maybe MINI does as well....Good luck, & please let us know what dealer says if you go.
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Aug 27, 2015 03:18 PM
Tires, Wheels & Brakes
Aug 26, 2015 10:13 AM
ASRman
Aug 13, 2015 09:33 AM
fm.illuminatus
Aug 10, 2015 12:15 AM
