R56 Strange Cruise Control Issue
Old Nov 4, 2008 | 01:37 AM
wv-mini's Avatar
wv-mini
I usually drive my car 4 mph over the speed limit on interstates (the margin of error for most police radar guns). When driving, I usually set the cruise control to 79 mph. Just the other day, while driving, I was using the +/- on the steering wheel to adjust the speed and it stopped allowing me to set it at 79 mph. It would jump from 78 to 80 and vice versa. I turned off the cruise, turned it back on and the same thing. It will set at 75,76,77,78, and then it jumps to 80, 81, etc.
Any ideas?
Old Nov 4, 2008 | 05:14 AM
wv-mini's Avatar
wv-mini
Bump
Old Nov 4, 2008 | 05:20 AM
Kazy's Avatar
Kazy
The +/- buttons adjust the cruise control by 2mph, not just one
Old Nov 4, 2008 | 06:18 AM
NSX JR's Avatar
NSX JR
The speed indicated is about 5% optimistic anyway, so you can add 3mph above 60 (68 indicated = 65 actual). This in no way answers your question, but seemed relevant.
I have had mine do the same thing, but it was pretty random and has not done it again.
Old Nov 4, 2008 | 08:43 AM
tambi's Avatar
tambi
What happens if you drive @ 79mph and then turn on cruise control?
Old Nov 4, 2008 | 08:49 AM
driverphil's Avatar
driverphil
My understanding is that the underlying speed is figured in KPH and then converted to MPH. Some speeds going from kilometers to miles cause the skipping.
It's a MINI thing
Old Nov 4, 2008 | 09:19 AM
whoapower's Avatar
whoapower
Mine increments by one either way. Has not behaved in any odd fashion. My commute to work goes through two school zones and two speed traps, so I use it religiously.
Old Nov 4, 2008 | 12:49 PM
bcski's Avatar
bcski
I have an 08 MCS and I can increase or decrease by 1
Old Nov 4, 2008 | 01:17 PM
wv-mini's Avatar
wv-mini
It usually sets at 80 mph, but I believe it has also set at 78 mph.
Old Nov 4, 2008 | 02:28 PM
pilotart's Avatar
pilotart
'08 MCa also +1/-1 with a tap on CC button.
And you always subtract about 6% to know the true speed.
Last edited by pilotart; Nov 4, 2008 at 09:37 PM. Reason: add speed correction factor
Old Nov 4, 2008 | 08:04 PM
RJKimbell's Avatar
RJKimbell
Mine on occasion does this as well, I've learned just to adjust it as needed. BTW...I'm running 4mph over. Not seeing any funny lights...yet!!
Old Nov 4, 2008 | 09:53 PM
Robin Casady's Avatar
Robin Casady
Not all speedos are going to be off by the exact same amount. The reason they read optimistic is to cover for possible variance from one car to another. Also, the exact size of your tires will have an effect. Best to calibrate before you try hitting the exact tolerances of law enforcement.
W0TM8
Dec 19, 2019 07:50 AM
minicooperlover22
Northwestern Indiana MINIacs
Aug 14, 2015 03:13 PM
PatrikKN
Aug 5, 2015 09:10 PM
Llanrhaeadr_Cymru
Country Roads MINIs
Aug 5, 2015 02:58 PM
