R52 Reset Window Indexing
Old Nov 3, 2008 | 05:29 AM
awood279's Avatar
awood279
Does anyone know the process to reset the window indexing on the 06 cabrio?
I recently had the passengers side front side glass replaced but the technician didn't remove the chunks of glass that were stuck up in the top molding so the window motor reset the indexing due to the resistance. So now the window stops before it is fully up in the molding.
Thanks for any help!
Old Nov 3, 2008 | 07:04 AM
Mishka's Avatar
Mishka
If I remember correctly, raise the window all the way and hold the switch for several seconds (five, I think).
Old Nov 3, 2008 | 08:40 AM
awood279's Avatar
awood279
Is there any ignition sequence that I need to do first? Does the car need to be off? Or just roll down the window then roll it up and hold it for a couple seconds?
thanks!
Old Nov 3, 2008 | 09:24 AM
Mishka's Avatar
Mishka
I just found an entry in my owner's manual that says:
1) Close doors
2) Close windows
3) Hold both window toggles up for approximately one second
This is if the windows aren't dropping when you open the door, but I would think it would work for your problem, too.
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
Fordgt4
Oct 10, 2015 10:42 AM
mk1leg
Classic Mini Talk
Oct 2, 2015 11:35 AM
rt808
Sep 25, 2015 01:59 PM
