R50/53 Spark plug ejection
Old Oct 31, 2008 | 04:18 PM
Cali44redrocket's Avatar
Cali44redrocket
Spark plug ejection
So has anybody out there had to deal with changing their plugs then the subsequent ejaculation of them out of their seat? Just trying to see whats the best method to avoid this BESIDES the standard 21 ft lbs of torque needed to seat them right.
Time for the change and don't wanna go into the shop for big time repairs!
Old Oct 31, 2008 | 06:19 PM
howie289's Avatar
howie289
My advice:
- Engine should be absolutely cold before removing plugs. Alloy is soft when hot.
- Compare old plugs with new plugs to ensure you've got the correct parts
- Apply anti-seize on the threads of the new plugs before installing
- Without using the ratchet, use your fingers with the socket extension to screw in the new plug. If there's resistance, you might be cross-threading so unscrew and try again
- After all plugs are finger-tight, use the torque wrench to finally tighten to spec
Some people also advise to re-check the torque on the plugs after driving a few days. Just be sure engine is cold if you do this.
Old Oct 31, 2008 | 08:00 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Cali44redrocket
...Just trying to see whats the best method to avoid this BESIDES the standard 21 ft lbs of torque needed to seat them right....
Don't change plugs unless the head is stone cold. Not warm. Cold. Anti-seize on the threads and 21 ft/lbs of torque with a quality torque wrench.
I check mine every 5000 miles when I change the oil. In 30,000 miles none of them have been loose at all.
Rich
Old Oct 31, 2008 | 08:15 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Great advise already given. cold, torque, antiseize. Also make sure you use good plugs like these: http://www.waymotorworks.com/product...cat=274&page=1
Some other aftermarket plugs are more prone to come out with the threads.
Don't stress it won't be too hard.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Oct 31, 2008 | 09:00 PM
Ryephile's Avatar
Ryephile
Another good point is based on the fact the MINI uses crush washer seats for its spark plugs. This means with fresh plugs you have to literally crush the gasket washer that seals the plug between the combustion chamber and the outside world. Most new plugs will NOT fully crush that washer if you simply torque to 21 lb/ft after snugging the plug up. You need to feel the crush washer collapse before paying attention to the torque wrench. This is very similar to tightening a cylinder head bolt by stretch, not just torque.
I hope that helps provide good insight. When you understand how the system works you're much more likely to built it and maintain it correctly. Torque values by themselves mean virtually nothing.
Cheers,
Ryan
Old Oct 31, 2008 | 11:59 PM
Cali44redrocket
Wow! Thanks for all the feedback from everybody on here! It's much appreciated thats for sure.....I'll let everybody know what how the project goes!
Old Nov 1, 2008 | 01:55 AM
markjenn's Avatar
markjenn
This makes no sense. If it takes more than 21 to compress the crush washer, then how can you torque it to 21 after it compresses?
No need to overthink this. Just torque it to 21. It will compress the crush washer fine.
- Mark
Old Nov 6, 2008 | 09:20 PM
Ryephile's Avatar
Ryephile
It makes no sense if you've never experienced it. The torque needed to crush the washer may exceed the final torque spec. The moral of the story is; if you can't feel the washer crush on a fresh plug, then you should remove it and inspect the washer to ensure it's fully crushed. If the washer isn't crushed, you haven't finished installing the spark plug. This is far more important than a simple blind torque specification on what is essentially a torque-to-yield system.
eliseo1981
May 10, 2016 05:19 AM
CRC
Sep 14, 2015 07:27 AM
JMF1975
Sep 11, 2015 03:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
