Coolant discolored
Old Oct 27, 2008 | 01:49 PM
Stanley07's Avatar
Stanley07
Coolant discolored
I just did an oil change on my 07 MCS (Feb 07 build) and noticed that the coolant in the reservoir is green/brown color instead of the blue it should be. The oil was fine so I don't think is a blow head gasket (no chocolate milk). My SA is researching to see if there is TSB but I thought I would throw this out to the board also. Anybody have or heard of this issue? I did a thread search but no luck there.
Old Oct 28, 2008 | 08:54 AM
djam43's Avatar
djam43
Is it possible that you introduced an incompatable antifreeze with the OEM and you are getting a reaction. The only antifreeze that is recommended for the Mini in addition to the OEM stuff, is Zerex G05.
Old Oct 28, 2008 | 10:05 AM
Stanley07's Avatar
Stanley07
To my knowledge, no coolant has ever been added to my car. Not even at the first service interval according to the dealr SA. What is in there was put in at the factory. So unless Mini put in the wrong type.... Idonno
Old Oct 28, 2008 | 10:08 AM
djam43's Avatar
djam43
Then if you are satisfied that there is no leak, I would have them do a full fluid change and keep a good eye on it in the future.
Old Oct 28, 2008 | 05:17 PM
MotorMouth's Avatar
MotorMouth
I've seen this before on used MINIs. I think the stuff just turns brown after awhile.
Old Oct 29, 2008 | 05:27 AM
Stanley07's Avatar
Stanley07
How about in your car? Has the coolant color changed? I got my MCS 2 month after you according to your sig.
Old Oct 29, 2008 | 09:05 AM
MotorMouth's Avatar
MotorMouth
I haven't looked!
maybe later today after it gets daylight I'll check.
Old Oct 29, 2008 | 09:56 AM
Noegel's Avatar
Noegel
How many miles? I've a tick over 5000 and it is still Jolly Rancher Blue.
Old Oct 29, 2008 | 11:25 AM
Stanley07's Avatar
Stanley07
I first noticed it at 26K.
Old Oct 29, 2008 | 11:52 AM
MotorMouth's Avatar
MotorMouth
I just checked. My water is dirty gray looking. 29k miles.
Old Oct 31, 2008 | 07:52 AM
djam43's Avatar
djam43
Dirty gray or brown color coolant!!! . I think it is time to change it out, as it has picked up contaminents somewhere. These aluminium engines need the best of internal corrosion available for the longevity of the beast. I would not rely on Mini to fess up that their coolant sucks, because it is hard to prove and will be will be long out of warrenty.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
vulkandino
Oct 31, 2015 08:29 PM
M7Speed
Oct 1, 2015 07:05 AM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
