Solo Shoulder harness
Shoulder harness
Does anyone know of a harness like the Schroth Rallye that fits in a 2008 MINI? Given that Schroth still doesn’t have one for the 2007+ cars leads me to believe they won’t ever. I have a lap belt lock, but it isn’t enough; I’ve got a bad back and it kills me in tight turns.
TIA,
Rob
TIA,
Rob
Rob
The CG lock wont help with the shoulder belt being loose, if you get the belt tight enough it really does a good job at keeping you in the seat.
I have heard that Schroth is in the process of testing the seats of the new cars to see if they meet the req's for their harness. So it may be available soon.
TIA,
Rob
TIA,
Rob
Craig
But is there really any reason to believe the R56 seat backs are that much different from the earlier MINIs? I guess the potential problem with the harness over the shoulder belt is that I pitch forward, the seatback behind me collapses, which causes slack in the shoulder belts, so I pitch forward more and do a facial into the wheel. I still think I'd be better off with the Schroth than the shoulder belt, but I'm only intuiting that.
Rob
The problem would be in a frontal collision when the seat back fails and you end up compressing your spine and doing who knows what kind of damage. The only reason the Schroth harness is approved to be used is because they test the seats to make sure they don't fail. The harness attaches to a point much lower than your shoulders.
I wouldn't use it on the street anyway, this is the Solo section.
Its more than sufficient for SCCA Solo usage, which is what it was really designed for anyway I think. I would be hesitant to use it on the track, I am not sure what would happen if you flipped and the roof smashed in on you. I guess you woudl get smashed with the roof unfortunately.
But if they can't get a 2008 version, then maybe I'll try the old model. At the autocross; not on the street.
Rob
So there is no way for someone to hit something while at the Solo track?
And yes in a rollover you would be at a bit of a disadvantage, but then again you would be in about the same condition with the stock belt.
I don't advocate using the Schroth on the street either.
I agree. Being in control is most important; you’d really have to loose it to hit something hard at an autocross. I probably wouldn’t use one at the track without knowing more, and in any case I don’t think my club (BMW CCA) would allow it anyway. And on the street it really impedes your ability to look behind, so it’s too much of a pain.
I’ll wait until late winter to see if they get new models going. If not, I’ll probably go with the older one on my R56 as suggested.
Rob
Rob
wildwestrider
11
Jan 29, 2016 05:06 PM
