Excessive wind noise from closed sunroof
Old Oct 21, 2008 | 11:06 PM
Corey986's Avatar
Corey986
mine goes away if I slightly lift the roof.
Is this normal...
Old Oct 22, 2008 | 05:08 AM
Minidrivr's Avatar
Minidrivr
Not normal. It needs adjustment. Mine is dead quiet when closed.
Old Oct 22, 2008 | 09:48 AM
matty125's Avatar
matty125
is it a high pitched whistle? You 100% positives its the sky light?
Old Nov 2, 2008 | 01:02 AM
Dinlaka's Avatar
Dinlaka
Mine had a strong wind noise and I'm pretty sure it's from the sunroof. Yesterday I took it in to get sport stripes put on so I had the service department looked into it.
When all is done, the rep told me that the sunroof wind noise is a known problem and they took care of it per bulletin. I believe they put a seal of black goo around the sunroof. It made a difference although the noise hasn't completely go away. It's defintely better.
I will have to drive it on highway more to verify if it's completely gone after the seal is completely dried.
If you have the same problem with the wind noise from sunroof at high speed, take it in to the dealer.
Old Nov 2, 2008 | 07:38 AM
pilotart's Avatar
pilotart
Absolutely no Sunroof related wind noise (when closed) at high speed.
Also no leaks from frequent Pressure Washing (1800 PSI).
Some have reported wind noise from upper area of windshield as well.
Couple feet of plastic or rubber tubing can be used as a 'stethoscope' to locate source of a wind noise.
Old Nov 13, 2008 | 10:59 AM
russr's Avatar
russr
I just wanted to add that I also get wind noise from my sunroof while going faster than 50-60mph especially if it is a windy day. I took it to the dealer and the foreman I test drove with told me that there's no whistling so it wasn't a leak. He said it sounded like all the other R56s he'd driven. I'm taking it in to get it examined nonetheless.
Old Nov 13, 2008 | 01:00 PM
Minidrivr's Avatar
Minidrivr
Once in a while in a heavy 20+ mph side/head wind, my sunroof makes a little wind noise. It doesn't happen every time though. There is a lot of adjustment on the sunroof glass. They should be able to quiet it down.
Old Nov 13, 2008 | 01:23 PM
corcoranwtnet's Avatar
corcoranwtnet
My 2009 MCSa is six weeks old. So far (k.o.w.) no leaks or wind noise from sunroof.
Old Nov 14, 2008 | 01:54 PM
todoubled's Avatar
todoubled
i think its coming from top of door window
Old Nov 16, 2008 | 03:50 PM
wwjd's Avatar
wwjd
I took my new jcw yesterday, it happens on my car as well...
It sounds like whistling.
I will take her to the dealer tomorrow.
Old Dec 10, 2008 | 12:20 PM
marendt428's Avatar
marendt428
Just got a brand new 2009 JCW and yes indeed I am hearing the same wind noise. It happens at about 60-70mph. I am going to get it taken care of when I get my tires rotated. I also have a 2008 base cooper as well with no sunroof and I get a different whine at about 65mph, to me it sounds like it is the grill or something on the front of the car, has anyone heard this as well???
Old Dec 10, 2008 | 12:37 PM
russr's Avatar
russr
Honestly, I wouldn't bother. They all do it. When I took it in, they told me that the new ones on the lot do the same thing. It has more to do with the shape of the car than anything else. As you can guess, our car is not very aerodynamic in the front and this causes the issue. Try driving around with ur sunroof open and u'll notice it makes a lot more noise than like a camry or altima.
When I took mine in, they tested it for leaks and so forth and found none. Unless there's something actually wrong with the sunroof, I don't think there's anything they can do to help you out.
Old Jan 29, 2009 | 07:38 PM
JeffN's Avatar
JeffN
the r56 sunroof does have some noise, BUT ive noticed MANY are mis-adjusted from the factory and do make noise above 50-60ish.
Pushing up on the sunroof fixes this because the front edge of the glass is supposed to be somewhat down and the back end upward. same with the 2nd glass panel. having the front edge of the front or rear glass up will catch wind and create noise. there are specific measurements for the height of each glass panel.
take it in to the dealer and have it fixed. if the dealer is any good it should be done in about 30-45 min. they wont be DEAD silent like a hardtop r56 but it should be somewhat close.
Old Feb 19, 2009 | 12:12 PM
toughluck's Avatar
toughluck
just picked up our pw/w yesterday and drove it on the highway. it was so loud I couldn't hear the person talking next to me. So I took it to the dealer today. They confirmed it and stated it was the sealant on the sunroof.
While they were fixing it, I got to drive another mini and took it down the highway. It was noticeably more quiet so I was able to verify that indeed there was something wrong with the one we had.
I'd encourage you to have it checked out if the noise level makes it difficult listening to a normal level speaking. We even turned off the radio. . .
Old Feb 19, 2009 | 01:13 PM
misslindsey's Avatar
misslindsey
A few months after I got Lewis the sunroof started sqeaking horribly. Dealer lubed something and was all good for a while. This fall it started to whistle as others have described. Favorite MINI Tech knew exactly what the problem was and fixed it straightaway, no more whistling, but it does squeak again now that it's cold.
Old Feb 23, 2009 | 08:02 AM
Augie05's Avatar
Augie05
I have the noise issue as well with my sunroof. The situation looks exactly as described below in this quote. I need to confirm that my dealer can adjust the sunroof so that it sits properly before making the 200+ mile round trip. The other "fix" with the seal does not seem like a 100% fix to me....
Old Mar 4, 2009 | 07:50 AM
leek's Avatar
leek
We complained a few times, they said it wasn't noisier than usual. This last time it was in for Airbag light (for the 3rd time) and they said there was an adjustment they could make to help with the wind noise. It now seems better.
Old Mar 17, 2009 | 05:35 AM
SNOTQT's Avatar
SNOTQT
Sunroof Cover
If BMW would have put a solid sliding shade or cover like most every car make so that the sunlight could be blocked out, the noise would be minimized. When I picked my Clubman up and saw that there was no opaque cover I was very dissapointed. I had a Subaru and an F-150 and both had sunroofs, to cut out the wind noise (when the sunroof was closed) I would close the shade. Those shaes have insulating properties.
Has anyone tried that Zippy shade that I've seen on ebay?
Old Mar 17, 2009 | 09:30 AM
Minidrivr's Avatar
Minidrivr
There's been a few threads about the Zippy shades.
I have a set of these by Stratmosphere.
http://www.stratmosphere.com/mini_interior.htm
Old Mar 22, 2009 | 10:25 AM
dw8928's Avatar
dw8928
Limo tint
Get your sunroof tinted with high quality limo tint. Mine is great. I can see out but very little light comes back in to annoy. It is great. Plus it doesnt really cost much to get those two windows tinted.
Old Apr 8, 2009 | 01:50 PM
LOP's Avatar
LOP
That's what I did right after delivery of the vehicle...made a world of difference for $50 and looks OEM...no shades to deal with.
Old Apr 9, 2009 | 08:00 AM
sequence's Avatar
sequence
Ive noticed a lot more wind noise in general with the R56 when compared to the R53, esp over 50mph. What gives?
Old Apr 9, 2009 | 08:02 AM
sequence's Avatar
sequence
People have been complaining about this since the cars were introduced in 2002, including me, and MINI has done nothing. what is so damned hard about designing and implementing an opaque shade fcol???
Old Apr 10, 2009 | 11:48 AM
LOP's Avatar
LOP
Fixed!
Had Cricket in yesterday and they adjusted sunroof...no more wind noise until I hit triple digits
lweaver
Sep 17, 2024 08:22 AM
ToyCar
Nov 19, 2023 05:20 AM
patsum
26
May 29, 2021 06:29 PM
Supertractor3
Apr 7, 2017 11:16 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
