215 or 225 ??? That is the question???
Old Sep 17, 2003 | 04:05 AM
Nobull60's Avatar
Nobull60
Getting ready to get new tires and rims and I am wanting to know if I should go with the 215 or 225?? The tire guy I am dealing with thinks 225 its the way to go. Going with the MOMO X-1. I know they are not light but I don't care about that. But they are lighter then the stock wheels I have now. Your thoughts and ideas. Thanks
Old Sep 17, 2003 | 05:08 AM
twstlvr's Avatar
twstlvr
Nobull60,
You may want to speak with Alex at Tire Rack on this one. I believe that wheel width has an important role in determining how wide the tire can be. I'm not sure how wide a tire can be installed on a 7" wide wheel. I know I had a set of 8" wide wheels and I needed to use the 215 versus the factory 205 so they weren't stretched across the wheel. You may have to have a minimun width wheel in order to use a 225. The other issue will be whether or not the car is lowered. My 8" wide wheels, with a more agressive offset, had 215/40/17 and I still had rubbing issues with H-Sport springs. The new wheels are 7.5" wide and I'm using the same tire with no rubbing issues at all.
Jason
Old Sep 17, 2003 | 08:22 AM
Alex@tirerack's Avatar
Alex@tirerack
get your dremel ready - every 225 in 17 inch I have seen takes trimming.
215 is the less likely to rub option.
Alex
Old Sep 17, 2003 | 09:43 AM
Nobull60's Avatar
Nobull60
Thanks for the advice. Glad I got anothr opinion from someone else in the tire field. Thanks
Old Sep 17, 2003 | 09:48 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I hate trouble. I'd go for 215 anyday. 225 isn't going to give you that much more in terms of function or looks in my opinion. People will look at those rims! Fool them- go with the 215.
Old Sep 17, 2003 | 10:51 AM
red03miniS's Avatar
red03miniS
i would say 215
i am running 215/45 yoko es..and it is rubbing rear right already
225 is not going to be adviseable imo
Old Sep 17, 2003 | 02:06 PM
SSRgeoff's Avatar
SSRgeoff
I saw that Hartge did there Mini with the front being 215x35x18 and the rear 225x35x18 both on 7.5" rims.
iclancy82
Jan 2, 2021 08:59 PM
donniedarko
Oct 21, 2015 01:15 PM
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
Panik
Sep 9, 2015 08:36 AM
