Suspension ireland engineering fixed camber kit(r56)
Old Oct 19, 2008 | 12:31 PM
boratufan's Avatar
boratufan
ı have fixed camber kit (street and track) and kw v3 coilover
ı have got two problems
1)ı turn steering wheel hardly:S
2)ıf ı getting more (-)camber,front sway bar stabilizer link is touching inner of the car:S
Old Oct 20, 2008 | 01:11 PM
boratufan's Avatar
boratufan
ı can not understand why ı turn steering wheel hardly..?
Old Oct 20, 2008 | 03:06 PM
JAceMin's Avatar
JAceMin
did you try turning softly or are little voices telling you to turn it hardly?
Old Oct 20, 2008 | 03:19 PM
boratufan's Avatar
boratufan
(-1.5 camber) ı can not turn steering whell easily:S ı think bearing in the camber kit is closely pressed:S
Old Oct 22, 2008 | 09:42 PM
4cefed4's Avatar
4cefed4
The steering wheel being harder to turn would probably be the result of your lowering the car and altering the suspension geometry. Caster is what typically gives cars different steering weights. The bearing in the camber kit would most likely just cause "popping" sounds when turning the steering wheel at low speeds, rather than making turning the steering wheel more difficult. Did you install the KW V3s and the camber plates at the same time?
Old Oct 25, 2008 | 11:25 AM
boratufan's Avatar
boratufan
hi
first of all,thank you for your explainations...yesssss making turning steering wheel more difficult:S ı thınk that my bearing is going bad
and ı have ordered new oneı am goıng to try again...
Old Oct 27, 2008 | 11:54 AM
boratufan's Avatar
boratufan
hi again:S ı dont understand that why ı can not turn steering wheel easily:S
ı controlled caster settings ..result: there is no problem:S
why????
Old Oct 27, 2008 | 11:55 AM
boratufan's Avatar
boratufan
-1,5 negative camber
-1 toe in
Old Nov 16, 2008 | 07:19 PM
maacodale's Avatar
maacodale
All I can ofer is that I have the Ireland fixed camber plates on my 07 MCS and have no problems at all. In fact I'll be ordering them for my 09 Clubman soon.
Aug 14, 2015 01:45 PM
Aug 14, 2015 01:44 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
