Drivetrain alta exhaust rattle any ideas???
Old Oct 17, 2008 | 10:57 AM
tommy_zito's Avatar
tommy_zito
i just installed a 2.5 alta catback on my 05...when i take off in 1st gear im getting a rattle and sort of a knocking sound comming from under the front seats...any ideas and possible fixes for this..??? thanks for your help!!
Old Oct 17, 2008 | 12:04 PM
ninjlao's Avatar
ninjlao
Ninja Mini
If you didn't cut some of the underbrace where the resonator hangers are that's probably it. I had a similar problem to yours and had the under plate cut to allow movement of the resonator, otherwise the resonator would hit the plate and it made a really annoyingly loud vibration sound.
Old Oct 17, 2008 | 12:35 PM
tommy_zito's Avatar
tommy_zito
ya I figured it out. I didn't cut it how ever I just took a pair of vice grips and bent the little lip down to allow clearance.
Old Oct 17, 2008 | 12:36 PM
glnr13's Avatar
glnr13
edit: nevermind
Old Oct 17, 2008 | 01:27 PM
tommy_zito's Avatar
tommy_zito
Originally Posted by glnr13
edit: nevermind
thanks for looking tho!
Old Nov 3, 2008 | 01:48 PM
agranger's Avatar
agranger
I had a very similar problem.
I had the B&M short shifter installed (which lowers the shifter housing about 1" into the exhaust channel) and the Alta 2.5 cat-back. The resonator that came with the Alta was so large that it was trapping the heat shielding between the shifter housing and the top of the resonator. I had a bottle-type resonator from Vibrant installed in place of the Alta unit to get some more room and things got better. I then had a bit of welding slag from the new resonator touching the black rectangular cross brace, causing some problems, but a grinding wheel took care of that!
I might also recommend checking your exhaust hangers. All of my rubber hangers were shot from heat and stress... a fresh set helped out a lot.
Teh
Aug 22, 2022 04:37 AM
TREX
Nov 2, 2019 07:31 PM
AWOL
Mar 28, 2016 10:51 AM
alistaircookie
Oct 8, 2015 10:52 AM
stierzy34
Sep 15, 2015 04:40 PM
