Brake Replacement 9 months after replacing?
Old Oct 13, 2008 | 08:45 AM
mrry550's Avatar
mrry550
We had our front brakes replaced by a mini dealership in early January this year - they replaced the pads and the rotors and also flushed the brake fluid.
So, I took the car in because I think we need to do the back ones done.. and the local mechanic tells me I need to have the front discs, pads and rotors replaced again.
Thoughts? Is this normal? I can't really tell how many miles I should expect out of my brakes.
Old Oct 13, 2008 | 08:51 AM
r52pimp's Avatar
r52pimp
Depends on your driving style and conditions. If you drive up and down hills, or in the canyons, or in a lot of traffic you brake life expectancy will be shorter.
Old Oct 13, 2008 | 08:52 AM
mrry550's Avatar
mrry550
I work from home, so we rarely drive the car. I think we put maybe 4000 miles on since January. It's suburban Cary, NC driving - so not much traffic or hills.
Old Oct 13, 2008 | 08:54 AM
D3m0N's Avatar
D3m0N
I would check for bad caliper?
Old Oct 13, 2008 | 08:56 AM
lhoboy's Avatar
lhoboy
Something isn't right. I use (abuse) my brakes hard, and get 20-30k miles from a set of pads/rotors.
Old Oct 13, 2008 | 09:00 AM
mrry550's Avatar
mrry550
I agree... I just spoke to the mechanic again and they are saying it looks like the rotors were never replaced in January (there is significant wear and they are saying there is no way that could have happen in the miles we've driven), and the pads are glazed. Says it looks like the dealer put on cheap pads. :(
Old Oct 13, 2008 | 09:01 AM
BLUCOOPR's Avatar
BLUCOOPR
I drive mine as hard as anyone and have almost 70K miles on the original brakes and will need new rotors before pads, I guess being a retired trucker and not using brakes but downshifting has helped alot. Sounds like dealership needs some molah to me.
Old Oct 13, 2008 | 09:04 AM
mrry550's Avatar
mrry550
Not surprisingly, this is not the first time that the dealer has said they've done work that was not done. :( The local place has really treated us well.
Old Oct 13, 2008 | 10:30 AM
AutoXCooper.com's Avatar
AutoXCooper.com
something smells fishy. I encourage you to take a drive over to NAM vendor http://www.grassrootsgarage.com/ and have them look at it.
maestro39
Oct 27, 2015 02:38 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
thebordella
Aug 31, 2015 01:37 PM
JPMontes3
Aug 23, 2015 01:26 AM
nomar116
Aug 10, 2015 11:24 PM
