"Groaning" in low speed turns?
Old Oct 12, 2008 | 05:55 PM
Z06C5R's Avatar
Z06C5R
I've noticed there seems to be a "groaning" noise when I make sharp low speed turns, like in parking lots... It doesn't seem to be directly associated with turning the wheel - sometimes it makes the noise while I'm holding the wheel steady through the middle of the turn. I cannot reproduce the noise by turning the wheel while stationary; it only happens while moving. Not sure if this is just a normal noise having something to do with the different speeds of each drive wheel and the LSD, or if it's a PS issue I should have looked at. Any thoughts?
Old Oct 12, 2008 | 06:36 PM
Crashton's Avatar
Crashton
There is a MINI TSB on that very issue. It is the LSD making the noise. The TSB is for a change to a different spec of tranny fluid. I had the TSB preformed on my car & the moaning went away.
Old Oct 13, 2008 | 08:31 AM
Z06C5R's Avatar
Z06C5R
Kool. More to pester the dealer with!
silence2-38554
Nov 12, 2015 09:39 AM
theblackfalcon
Oct 11, 2015 09:49 AM
David.R53
Sep 1, 2015 06:51 PM
xpunisherx
Aug 10, 2015 10:50 PM
