Drivetrain Is my exhaust leaking?
Old Oct 9, 2008 | 01:41 AM
Mike S's Avatar
Mike S
I went to look at my car at the shop today while all it's goodies are being fitted on.
I noticed on only the rear half section of the exhaust system that there is some black soot. Do you think it is leaking from this bracket? I asked the mechanic and he says it's normal, but then it should be on the entire exhaust and not just the rear half?
Also notice where it splits to the 2 mufflers. Only the one side has the black soot, I think it may be leaking from the weld?
Old Oct 9, 2008 | 06:40 AM
quikmni's Avatar
quikmni
There is a slight leak. Water will mix with the exhaust soot in the pipe and leak out when the exhaust is cold. If it is a small leak, it will seal up when the exhaust gets hot and the metal expands. It normally is not a problem. Only a problem if there is a big leak that will not seal when hot. From your pictures, yours looks normal.
Old Oct 9, 2008 | 07:39 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
+1 well stated.
Old Oct 9, 2008 | 08:40 AM
checkmate2006's Avatar
checkmate2006
V-bands = NO LEAKS
Old Oct 9, 2008 | 01:46 PM
Mike S's Avatar
Mike S
Alright, I will leave it as is. Thanks for the info - a new thing that I learned yet again!
speedyg56
May 18, 2020 08:52 AM
gmonde
Sep 8, 2015 06:37 AM
ShadyCoop
Aug 24, 2015 06:05 AM
elightbo
Aug 17, 2015 01:50 PM
ASRman
Aug 13, 2015 09:33 AM
