Drivetrain HELP! Air in ASC during bleed
Old Oct 8, 2008 | 10:25 PM
smportis's Avatar
smportis
SOLVED - HELP! Air in ASC during bleed
Yes, I've done the dreaded "Don't ever do this!" thing and accidentally sucked the master reservoir dry using a vacuum bleeder.
Now it seems that I can't get rid of the dead brake pedal. I've run 3 bottles of Motul 600 thru it, now am putting $7 bottles of DOT 4 thru it, but to no avail.
Time to go to the dealer? I've been doing this for 4 nights now.
PS - been pumping the pedal since I found the problem. No more vacuum bleeder.
smp
Old Oct 8, 2008 | 10:36 PM
verveAbsolut's Avatar
verveAbsolut
smp
Most likely got air into the ABS portion of the system. You'll have to take it to the dealer to have it cycled.
- Matt
Old Oct 9, 2008 | 09:48 AM
smportis's Avatar
smportis
Yep. Took it in. Hate to do that. Pedal totally to the floor the entire way - pumping did not give any pressure. Hand brake and gearing down for a 7 mile trip on some pretty tricky roads. Not fun.
Old Oct 9, 2008 | 09:46 PM
smportis's Avatar
smportis
Ha, it was not the ABS or the DSC at all - it is just me being a dumb@ss. I put the front calipers on backwards. Pure rookie mistake - looked so simple when I was trying to figure out which caliper went on which side after I painted them.
Guess I was wrong.
Having the calipers upside down does tend to create quite a bit of air pockets in them.
Sep 10, 2015 11:55 AM
M7Speed
Sep 3, 2015 07:48 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
