Non-runflat tire suggestions?
Old Oct 6, 2008 | 05:53 PM
minipb's Avatar
minipb
Any suggestions for a good tire somewhere between a high performance tire (non-runflat) and a conventional all season?
Old Oct 6, 2008 | 06:01 PM
slinger688's Avatar
slinger688
What you do with the car can help with the tire recommendations? There is a tradeoff among:
price
dry versus wet
longevity or wear
noise
winter driving capability
etc.
I am generally not a fan of all season tires.
Old Oct 7, 2008 | 10:12 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Need more info.
Year and model of your MINI.
Wheel size and current tire
Suspension- Stock vs lowered (how much)
How bad is your winter- mild or blizzard prone?
Any rain?
Budget and intended use- commuting or any performance driving?
How long do you want them to last- does it matter?
Lots of options depending on tire and wheel size.
Probably stick to All Season tires- so that you can run the same tire all year without making changes.
Ultra High Performance All Season tires give better handling but wear out faster and can give a firmer ride- depends on which tire.
Grand Touring All Season tires- are better for general street use but you trade some handling for more comfort and longer treadwear. Not all sizes are available- good for 15" and 16" sizes.
Old Oct 7, 2008 | 12:28 PM
slinger688's Avatar
slinger688
Minihune,
Is that a custom Koa dash I see in your pic? Looks really nice...
Old Oct 11, 2008 | 08:38 AM
minipb's Avatar
minipb
Okay more info--06 MCS stock; drive 2 miles to work; Maine winters but garage my precious when really bad. All Season is NOT a necessity. Still I bought the car to have fun with driving even though I don't "push it" except rarely and then very reasonably; I don't want to forfeit a bunch of handling but like I say, in reality, I am a pretty mild driver and Maine is quite rural. I just about fainted though when my dunlop oe run flats were shot after 16,000 and at $300+ I don't want to repaet that. Thanks in advance for the help!
Old Oct 11, 2008 | 09:09 AM
RaceTripper's Avatar
RaceTripper
I just ordered Bridgestone Potenza 960AS all-season non-runflats. They have been rated very highly in TireRack surveys and tests, and there are a lot of positive opinions abut them here at NAM. I didn't find any negative comments in my research. I paid $146 each for 215/45/17.
Old Oct 11, 2008 | 09:27 AM
slinger688's Avatar
slinger688
You are really brave not to have at least all seasons in Maine. Performance tires get really hard in the cold and are quite bad even when it is not snowing. With your description, I would at least go all seasons. It will not affect handling that much given your reasonable drivng. Do you want to stay with run flats?
PS: Are you one of those ice racers?
Old Oct 11, 2008 | 09:34 AM
RaceTripper
That's a great point I overlooked. Summer tires start to loose grip very quickly and drastically once the temp starts dropping below 40F or so.
Old Oct 11, 2008 | 04:55 PM
minipb's Avatar
minipb
I do not want to stay with runflats! I have gone through two winters already with the OEM Dunlops; not a big deal; but I want to go conventional; any opinions on Kumho's? Other suggestions?
Old Oct 11, 2008 | 05:09 PM
RaceTripper
I haven't used them but the Kumho Ecsta ASX were recommended to me. They run $89 each at TireRack. I was going to get them, but decided to spend the extra for the Bridgestones.
Old Oct 12, 2008 | 02:10 PM
minipb's Avatar
minipb
I REALLY appreciate the help--I know nothing about this stuff as should be obvious. One last thing: I now run 205/45/17's. Am I locked into the "205" or can that be different and by how much? Same question for the "45?"
Old Oct 12, 2008 | 02:27 PM
RaceTripper
You can go to 215/45/17. That's what I did.
Old Oct 12, 2008 | 02:34 PM
minihune's Avatar
minihune
Given your situation and use I would recommend the Bridgestone Potenza 960AS in 215/45-17 as well. No problem with the size being slighter taller than stock.
Should work fine all year summer or winter (go slower), and fit your MINI fine providing good handling and comfort and good treadwear at a decent price.
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
Kimolaoha
Dec 5, 2020 09:32 PM
TJANK
Aug 24, 2015 06:11 PM
sabjcw
Aug 14, 2015 07:40 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
