Suspension Powerflex upgrades
Old Oct 5, 2008 | 08:30 AM
Mike S's Avatar
Mike S
Powerflex upgrades
Hi guys,
This is my perdicament - I want to upgrade as many bushes as much, advised possible.
Also what should I leave out if I am getting the following parts:
  • ALTA Positive Steering Response System
  • VIP Engine Stablizer
  • TSW Rear Lower Control Arms (will keep the bushing that come with those).
So what do I leave out? Also how many will I need of each? Am I missing any other powerflex part?
http://www.promini.com/category-exec...arch_model/100
Have 1 more criteria, which vendor stocks the ALTA PSRS, VIP Engine Stab and Powerflex Bushes? I would like to save on shipping and will order all from 1 vendor. Unless there are vendors that you know of that will purchase the items they don't normally stock for me.
Thanks for your time!
Old Oct 6, 2008 | 05:35 AM
Mike S's Avatar
Mike S
Anyone?
Old Oct 6, 2008 | 06:00 AM
meb's Avatar
meb
I have no experience with the alta unit, but about 100,000 miles with Powerflex LCA bushing. This bushing works well, requires that the subframe be removed to install correctly, and, this bushing will get very hard when temps begin to drop in winter. It can be down right harsh!
You get better steering response and feel, but almost more importantly, these help reduce front end squishiness during hard braking.
Old Oct 6, 2008 | 06:10 AM
gnatster's Avatar
gnatster
I don't think you will find a vendor that carries all these items. I've only seen VIP parts for sale by them and no other reseller.
Old Oct 6, 2008 | 08:06 AM
Mike S's Avatar
Mike S
Thanks for the response. It never really gets too cold here, it's Africa after all So at least I won't have that problem. That squishy brake feeling is exactly what I want to get rid of!
Old Oct 6, 2008 | 08:26 AM
Mike S's Avatar
Mike S
I managed to come with an arrangement with Outmotoring. Which bushes should I buy if you take into consideration the parts I want to put in from the first post?
Old Oct 6, 2008 | 05:41 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
It seems like this has not been mentioned - deemed as understood, but I'd like to point out that the ALTA Positive Steering Response System and the powerflex control arm bushings are the same part. That is you can either have one or the other but not both.
Old Oct 7, 2008 | 12:26 AM
Mike S's Avatar
Mike S
Thanks nabe! I will keep that in mind. Like I said, I'm a serious motor noob First time I ever did work on my own car is now with the Mini. Really clueless about all the terminologies.
Old Oct 7, 2008 | 11:21 AM
meb's Avatar
meb
Okay, you confused me..."are the same part"...can have one or the other, but not both" I think you meant to write "are NOT the same part"...which is true.
I think either one will work.
Old Oct 7, 2008 | 11:28 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
What i ment was that they serve the same basic funtion - replacing the stock control arm bushings.
Old Oct 7, 2008 | 11:31 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Try "they fit in the same hole, and cannot be simultaneously installed without violating the fundamental laws of physics"
Old Oct 7, 2008 | 01:42 PM
Mike S's Avatar
Mike S
I have no clue what trailing arms etc. are, so when I first read the description on ALTA's website I was lost. Thanks again for clearing that up for me.
Old Oct 7, 2008 | 02:10 PM
meb's Avatar
meb
...well, given that one is plastic and the other steel...
Old Oct 7, 2008 | 05:43 PM
Chase's Avatar
Chase
Im happy with the Alta psrs
Old Oct 9, 2008 | 03:51 PM
OldRick's Avatar
OldRick
While you are in there, try the rear strut-top bushings. These replace the OEM foam rubber bushings. http://www.mini-madness.com/index.as...ROD&ProdID=260
BTW, why not get them all from one source, where you can also get some explanations?
http://www.mini-madness.com/index.as...S&Category=205
Old Oct 9, 2008 | 09:36 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I had no idea such a thing existed. I'm going to order these right now.
Oh, are these things strictly OEM, or can they be used with coilovers later on?
Old Oct 9, 2008 | 10:07 PM
Mike S's Avatar
Mike S
thanks rick, I'll have a look into it
Old Oct 10, 2008 | 05:35 AM
meb's Avatar
meb
...just add a little silver anti-sieze the the mating surfaces to prevent potential sqeeking...nothing worse than getting an install just perfect and finding you have to undo everything the eliminate a nasty, persistent sqeek.
Old Oct 10, 2008 | 09:50 AM
k-huevo's Avatar
k-huevo
There is a reason the top washer above the rear strut upper mount is dished and a rounded shaft shoulder with concave washer combine below the upper mount on the OEM strut assembly; it’s because the strut must be able to tilt with trailing arm rise and fall. The OEM bushing’s material is compliant enough to allow movement and soft enough for support. This engineered compliance is changed with poly’s increased durameter compound and increased stiffness which limits range of motion. I’ve been privy to anecdotal evidence of two seperate incidences of rear upper strut shaft fractures on MINIs with these Poly bushings. Poly adds a degree of non-linear “spring rate” to the suspension mix also.
In my experience, struts are the important component and there is no need for other band-aids, if well performing struts are in use. Unimpeded range of motion is our friend in need, not buckboard rigidity.
Old Oct 10, 2008 | 11:15 AM
OldRick's Avatar
OldRick
I think that these bushings causing damage would be a real stretch, as they are still compliant, just not as compressible as OEM. The amount of shock-top tilt with the amount of compression the shocks can do would be just a few degrees, at a guess
The mold for these bushings is taken directly from new original bushings, so they are exactly the same shape - hard to make out in the image, but the OEM part numbers are visible on the side of the urethane bushings...
BTW, they have been on the M-M car that is both daily driver and the winner in a couple of tuner run-offs, for several years with no problems.
Old Oct 10, 2008 | 12:34 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I respect everyone's input. It seems I will hold off on these untill I can get more data.
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
