Loss of 3-click and broken keys
Old Oct 2, 2008 | 06:18 AM
gokartride's Avatar
gokartride
Two issues/questions...
Occasionally I lose 3-click....very rare, but it happens. It bumps itself back to one-click. One time it self corrected the next time I started the car, either way it's easily re-programmable. Anybody else run into this or have insight into conditions that may cause it???
Second....the chrome ring around your key fog can break. It apparently happens now and again and this is known at the dealerships. I'm told there is a easy fix...a replacement ring just snaps into place. In any case, the chrome ring is trim only...it serves no other purpose. Not a big deal (mine is being fixed under warranty...I'm using the spare for now), I was just worried that the broken trim on my key would jam in the key dock.
Old Oct 2, 2008 | 06:38 AM
tim781996's Avatar
tim781996
My doors don't seem to automatically lock anymore even though I swear I set it to do that.
Old Oct 2, 2008 | 11:46 AM
LordRybo's Avatar
LordRybo
Seat To Wheel Spacer
Noob question, but what is 3-Click?
Old Oct 2, 2008 | 11:56 AM
meadbar's Avatar
meadbar
my chrome ring broke and dropped of so i fixed it with super glue
Old Oct 2, 2008 | 12:03 PM
pilotart's Avatar
pilotart
For a lane change signal.
You can program (each key fob) to have your choice of one or three blinks on turn signal,
if you move the lever half-way (detent felt) to turn signal on.
Old Oct 2, 2008 | 12:21 PM
TheBigNewt's Avatar
TheBigNewt
Your spare fob isn't programmed to 3 click. It'll work right when you use the original.
Old Oct 2, 2008 | 12:27 PM
gokartride's Avatar
gokartride
I'll reprogram the new one....I coulda swore it worked yesterday when I used the new key, but I could be mistaken (this happens alot ). I had forgotten the turn signal info was stored in the key, so that is a big help...thanks!
My SA said there is a replacement outer ring for the key that can be fitted in seconds.
Fordgt4
Oct 10, 2015 10:42 AM
B1mm3r101
Oct 1, 2015 06:22 AM
jennster
Sep 28, 2015 06:19 PM
EVMini
Sep 28, 2015 10:20 AM
daviday
Sep 25, 2015 01:31 AM
