R50/53 Missing bolt - need help
Old Sep 27, 2008 | 09:56 AM
mini&m3's Avatar
mini&m3
I am performing my first oil change on a 2004 MCS JCW- no big deal so far. I have run into one problem though - next to the oil drain plug (toward the passenger side) there is a threaded hole that looks like it should have a bolt in it. Any idea what size bolt should go there?
I have no idea where it could have gone, but I can't imagine it can be a good thing.
Thanks,
Bryan
Last edited by mini&m3; Sep 27, 2008 at 09:57 AM. Reason: Needed to add year and model
Old Sep 27, 2008 | 12:48 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Just checked one that's on the lift out here in my shop, and there is no bolt in that spot.
The threaded hole that is on the corner of the oil pan, right?
Old Sep 27, 2008 | 05:56 PM
orbitup's Avatar
orbitup
I would guess it's to pop the oil pan off after you take all of the bolts out. It threads into the pan and pushes on the engine block to break the seal. Beats prying it off with a screwdriver.
Old Sep 28, 2008 | 01:17 PM
mini&m3's Avatar
mini&m3
Whew!! Thanks for the info. I looked at it again after I posted and decided it wasn't a big problem. Helps to know that it is supposed to be that way.
Next...try to change the gear box oil!!!
patsum
26
May 29, 2021 06:29 PM
papawhiskey
Sep 14, 2015 05:47 PM
smbmkay
Sep 11, 2015 09:45 AM
Sep 10, 2015 10:52 AM
Sep 3, 2015 10:29 AM
