02 oxygen sensor questions
Old Sep 26, 2008 | 10:34 AM
Raiyu's Avatar
Raiyu
Hey it's time to replace the 02 sensor but I'm trying to figure out which one will be the best/least expensive option.
On rockauto they have ACDelco, Delphi, Bosch and Airtex ranging from $105 to $240.
Are there any real differences between these pieces or just the name? I want a good piece but why pay more for the same?
Thanks in advance for your insight
Old Sep 29, 2008 | 03:43 PM
frenchie's Avatar
frenchie
Buy something that is rated for OEM replacement, this label means it was tested and guaranteed to work in your particular car; these units also have the connector attached to the cable and does not require any cutting and soldering.
There are cheaper replacements out there that may work, but may require you to install the connector on the end. o2 sensors are very sensitive to resistance in the leads since they work on such low voltage. IMHO replace it with an exact unit since it is such a critical part in managing the engine, with the price of fuel nowadays you will not regret it!
Old Sep 30, 2008 | 05:26 AM
Bajanmini's Avatar
Bajanmini
The Bosch unit is original equip and are available outside of BMW for cheaper.I did this and it came as a straight install correct plug included.
alistaircookie
Oct 8, 2015 10:52 AM
thebordella
Aug 31, 2015 01:37 PM
Bennyboy
Aug 18, 2015 07:28 AM
Emnotek
Aug 13, 2015 05:47 PM
massmini03
Aug 12, 2015 11:19 AM
