Green Fluid Leak
Old Sep 24, 2008 | 02:56 PM
LGK's Avatar
LGK
Green Fluid Leak
I have noticed a Blueish Green thick fluid leaking out of my 2006 Cooper S with steptronic. Talked to the service department and they set up an appointment a week from now.
The fluid feels oily, is thick, but smells a bit like radiator fluid.
I drive 400 miles a week just to and from work, any thoughts about what this fluid could be and how to check/refill it before the steering goes out, or the brakes fail, or the car overheats, or tranny falls out.
LGK
Old Sep 24, 2008 | 04:24 PM
ej's Avatar
ej
Thermostat housing failure
Sounds like a failed thermostat causing the leak. Same symptoms with my car. Got it replaced under warrenty.
Do a search and you'll find numerous post regarding this.
Old May 2, 2009 | 12:03 AM
KandyRedCoi's Avatar
KandyRedCoi
yep, found that leak under my car today while doing my HD front lip install, will have the local dealer look at it this week, hopefuly its still under warranty, my 2006 has less than 30K miles on it
Old May 15, 2009 | 02:26 PM
joevista's Avatar
joevista
it should be no problem as long as its under 4yrs, thermostat housings go bad
Old May 16, 2009 | 01:26 AM
KandyRedCoi
yep got mine fixed at no cost to me
patsum
26
May 29, 2021 06:29 PM
hockeydad51
Oct 9, 2015 01:51 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 2, 2015 09:05 AM
