R56 fuel gauge - drove 87 miles before the first bar went black
Hello NAMers,
I have a R56 S 6 spd and usually shift 2500 ~ 3000 rpm for a normal drive, 3000 ~ 3500 rpm for a fast drive.
I drove usually 87 miles before first bar went black, but some times 77 miles before first bar went black so I wonder what miles drove before the first bar went black other R56 owners?
tag/ do you have a R56 or R56 S? If you have a R56 S and you drove 135 miles before first bar went black that's pretty well manage gas.... wow
I've had the first petal go dark as soon at 80mi and remain lit as long as 100mi. But I do mostly in-city driving. A lot of city driving.
FYI, there was a good thread on this here: https://www.northamericanmotoring.co...=147535&page=2
Check out post #31 - basically, the 1st petal is about 3gal, 2nd & 3rd petals are 2gal each, then one gal for every petal remaining. So, three dark petals = ~1/2tank.
100 or so.
I enjoy using the "consuption rate" on the tach and the OBC on road trips. Sets up a good game of "stretch the milage". The only reason to drive on roads without hills or curves.
The absolutely only reason.
The lights only represent roughly 90% of the tank. I have a OBD fuel gauge on mine and compare it to the lights and had at one point mapped out the lights to an actual gauge. The ECU reads the tank in percents and then in turn displays it via the lights in a incomplete manner. There is no reserve on tank. When empty, it means empty !
When the first light goes out, you are about 85%. If memory serves correctly, when you have 6 lights lit, you are 1/2 tank. The lights are NOT linear and to make a complete 100% gauge, roughly 2 lights are missing.
Paraffin, corn syrup, and sugar?
'Sides, mine aren't multi-colored, just orange. How'd you get your fuel "gauge" in a 3-color pattern?
Yes, a very non-linear gauge, and watch out for that "miles to empty" reading, which is very inaccurate once you're down to two or three lights. If the lights were proportional, we'd all be getting 1,000 miles per tank, based on the time it takes for the first two to go out!
That's ok, I'm secure in my masculinity.
