R56 start manual in second gear
Past few days I have been starting the car in the second gear instead of the first. Specially when I am at the lights, starting in second is so much more fun. Is there any harm to the car because of this ?
I start in 2nd all winter, but usually stick with 1st in the summer because I feel like I have to let the clutch slip a little more than I'd like in order to take off smoothly. But there's nothing wrong with starting in whatever gear you want as long as you can pull it off - you just have to live with the results (and hope you don't lose a clutch as soon as your free maintenance is up).
thats true, first will take you to 30. but its the first to the second. every time i get off the blocks, I start at first and then when changing to the second there is a lag which causes traffic behind me to get frustrated
I dont really have to give it up gas, rev it up for around 2.5 and its good to go.
I'm not sure why you want to start in second gear (unless you're on a slippery surface and want to minimize wheel spin), but I'll bet you end up slipping the clutch more doing that. That does not equate to longer clutch life.
i used to rev that high to engage in first when i was first learning manual. it was a lot easier to "engage" when you rev that high but not anymore. looking back, thats pretty high....
never really tried getting the car to start on 2nd... accidentally did it in 3rd a few times but it was a struggle....
IMO not enough torque to do it everyday without destroying the clutch
i had a 5.0 mustang with 3.73s in the rear end and u could pull away in 2nd gear all day without givin it any gas just lettin clutch out but it was a torque monster
^^less shifting, and it's a bit smoother than launching from 1st.
I only launch from 2nd on significant downgrades/downhills, less wear on the clutch, and of course one less shift.
If it's less shifting you want, then why have a manual? Get an Auto and you can have a lot less shifting.
If your good at it, you can chug the car rolling in 5th or 6th. But why would you? 1st gear is for launching, end of topic. If you on ice, still launch in 1st, with a fast shift into 2nd, if you don't have any traction control, otherwise let the traction control, and driving like there is an egg between your foot and the gas pedal get you moving on ice.
Mark
Mark
. In all seriousness, as a daily driver with pretty much the same route to work it's OK to want to skip a shift once in a while, especially this one steep hill I almost always sit at a red light every day. I.e. depends on the situation. Of course in the big picture would never give up my manual for an auto.
