Alternative instrument / gauge setup
Old Sep 8, 2008 | 08:58 PM
Motorsport's Avatar
Motorsport
So say you have the single big speedo in the center of your dash, and NOTHING ELSE...
What are some alternative gauge setups?
Can you remove the big central speedo, and then add a dash kit, with new smaller gauges centered on the steering column?
I hate not having a tach!
I'd love to see what gauge setups you guys are using.
Thanks!
Old Sep 9, 2008 | 04:23 AM
Minimad's Avatar
Minimad
Just go to minimania, minisport or sommerford mini and look up dashes...there's lots of custom stuff available, wood, metal, plastic, etc....
or make your own
http://www.minimania.com/web/threadi.../msgthread.cfm
this metal is available in 1/8" thickness at ACE hardware. I made mine.
Old Sep 9, 2008 | 06:06 PM
jeffm5150's Avatar
jeffm5150
I bought five gauges from Summit Racing that closely match the classic Mini gauges.
They are:
Mechanical water temp
Mechanical oil pressure
Voltmeter
Fuel gauge
Oil temperature
The water temp and oil pressure gauges replace the original gauges in the cluster, and the other three are mounted in a panel under the dash.
See attached picture
Hope it helps,
Jeff
Attached Thumbnails Alternative instrument / gauge setup-_mg_1945_800x600.jpg
Old Sep 10, 2008 | 08:36 AM
MiniVespa's Avatar
MiniVespa
Thats my dash set up. I'm still waiting on two more small guages to stuff in there.
Old Sep 11, 2008 | 04:10 PM
mk1leg's Avatar
mk1leg
Hi..here are some pics.............modern 3 clock set up..........
and old style wood ............
Old Sep 11, 2008 | 09:15 PM
joltfreak's Avatar
joltfreak
here's the one in my mini:
and here is one that i'm selling:
Old Sep 12, 2008 | 02:22 AM
Big Norm's Avatar
Big Norm
the sky is the limit....you can have one custom made or you can buy an aftermarket
Old Sep 12, 2008 | 07:14 AM
mk1leg's Avatar
mk1leg
Here's a home made custom dash.................
Old Sep 12, 2008 | 07:45 AM
joltfreak's Avatar
joltfreak
that's really sweet!
dinomaniac
Sep 18, 2018 04:19 AM
Oct 19, 2015 08:07 PM
RHcoopers
Sep 20, 2015 10:01 AM
Sc00terbum
Sep 11, 2015 09:07 AM
KinetechMW
Sep 10, 2015 03:12 PM
