Suspension HELP Needed
Old Sep 6, 2008 | 10:50 PM
jack112286's Avatar
jack112286
HELP Needed
anyone installed the koni yellow part number "8641-1432SPORT " on their R56?
I am looking for a write up. I finnish installing it, but for some reason the front sits one inch taller than factory.
fyi, this is the strut insert cartridge .
thanks. Jack
Old Sep 7, 2008 | 08:13 AM
Ryephile's Avatar
Ryephile
Just to be sure, you have driven around the block to settle the suspension, right? The suspension always sits higher after taking it off 'stands because the bushings and tires [and e-brake] are bound up.
Old Sep 7, 2008 | 02:07 PM
jack112286's Avatar
jack112286
i did take it for a short drive (less than 5 minute)
one thing I believe it might be is since I am putting the insert on the R56, the older shock(R53) might be shorter than mine, so after putting the insert into my stock shock housing, and mounting on the spring(off car), compare to my old one, i was already noticing a inch difference. this is my second time changing it on my car(i was putting in the sport suspension 2 week ago)...
Old Sep 7, 2008 | 03:49 PM
Ryephile's Avatar
Ryephile
The R53 Koni Yellow's were direct replacements. They didn't have inserts like you're describing. It sounds like what you have is not a stock replacement, more like either the wrong part number or the rally-cross model. Perhaps a call to your vendor or Koni tomorrow to straighten out the issue is in order.
Old Sep 7, 2008 | 10:44 PM
jack112286's Avatar
jack112286
from tire rack
http://www.tirerack.com/suspension/S...&perfcat=track
Front Fitment Housing: Cartridge Insert
Externally Adjustable
Note: Front fitment Twin Tube Low Pressure Gas Externally Adjustable McPherson Strut Cartridge For models before 3/1/02. The front sway bar attaches to spring seat. Excludes S models.
Price: $181.00 (each)
Estimated Availability: Special Order
Manufacturer Part #: 8641-1432SPORT
i selected the vehicle, and thats what one of the option came up was
mishanja
Jun 22, 2016 09:59 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
