Drivetrain safc2.... is there a how to yet?
Old Sep 6, 2008 | 01:54 PM
Malcon's Avatar
Malcon
I've been searching the forums for a while trying to find if there is a good how to instalation for the safc2 on here. i didnt really find anything. i saw one diagram, but Luckydoggarage said it was wrong... anyway if anybody has installed this and would share some info on how they did it that would be great!
I'm installing a water/meth setup and i'm using the safc along side that to get some gains from the setup.
thanks everybody!
Old Sep 6, 2008 | 04:09 PM
UKSUV's Avatar
UKSUV
Getting the diagrams for the SAFC2 is like finding the holy grail or torturing someone who has it. There are a few people on here that have it but it would prolly cost ya. Why should they spend all their time trying to figure the pin out just so someone can get it easy.....
Old Sep 6, 2008 | 05:04 PM
Malcon's Avatar
Malcon
wow...haha
If it were me that figured it out i would post it in a heart beat... but maybe I'm weird for liking to help people out...
one of the things i like most about the "mini community" is how much everybody helps each other out. i guess there are some exceptions.
so if there is anybody with information that they would want to share that would be awesome! thanks!
Old Sep 6, 2008 | 10:24 PM
1FSTMINI's Avatar
1FSTMINI
hope this helps.
Old Sep 6, 2008 | 10:53 PM
Malcon's Avatar
Malcon
this is very helpful.. but i read somewhere that this was incorrect...
Is this the diagram you used to setup your module?
thanks again for the help!!
Old Sep 7, 2008 | 12:44 AM
CarterMD's Avatar
CarterMD
Originally Posted by 1FSTMINI
hope this helps.
This is incorrect. Although the pins are described correctly and the SAFC/AFC NEO works the pressure signal is wrong and the car runs bad.
I also get every time I start up the car an error with a ground related situation on the pressure sensor channel. So.... does not work !
Old Sep 7, 2008 | 01:54 AM
Malcon's Avatar
Malcon
good to know.
You haven't tried to fix it?
Old Sep 7, 2008 | 07:07 AM
1FSTMINI's Avatar
1FSTMINI
i just had it saved from awhile ago when people were installing it....i never got to install mine as i went with Jans tune.
Old Sep 7, 2008 | 07:44 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Pm ingsoc!!!
He had it installed etc.
Jack
Old Sep 7, 2008 | 10:41 AM
Malcon's Avatar
Malcon
awesome thanks!
Old Sep 9, 2008 | 06:21 AM
Malcon's Avatar
Malcon
OK well its installed and working great! if anybody needs to know how to install the SAFC2 let me know! Hubie Fuh[FONT=Arial][SIZE=2][FONT=Arial] [/FONT][/SIZE][/FONT]from ABF performance was kind enough to send me a PDF with the instructions on how to install on a mini. easy to install! i did it in about an hour.
thanks again!
-Malcon
Old Sep 9, 2008 | 08:22 AM
1FSTMINI's Avatar
1FSTMINI
good to hear...now make sure you have it tuned on the dyno by someone who knows how to use it.
Old Sep 9, 2008 | 10:56 AM
Malcon's Avatar
Malcon
of course! right now its just cool being able see everything.
But yes i plan on having it professionally tuned with the water/meth setup..
and i'll also have another tune on there that will make everything stock. so if i dont have the water/meth i can switch the tune to the factory settings.
